shell rotella T - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 47 (permalink) Old 05-19-2009, 03:42 PM Thread Starter
Canadian Stroker
doubledoor's Avatar
shell rotella T
Does it make any difference running shell oil? compared to other oil. Like inj. noise or anything else. Just regular oil not syn.
Thanks
2002 XLT CC LB 6speed SRW
4"mbrp turbo back
S&B Intake
autometer NV boost,pyro,water temp and oil pressure
WW2,BRV
DP tunes - QI,60E,80E,40T,60T,100,120.
EBPV delete sensor.
blank pedestal and EBPV housing
ATS turbo housing
DI up-pipes.
2007 headlights,2008 taillights,2010 tailgate
17"Atx ledge with Dick Cepek Extreme Country
doubledoor is offline
post #2 of 47 (permalink) Old 05-19-2009, 04:29 PM
All done now
Arisley's Avatar
Re: shell rotella T
I would be almost willing to bet that about half the powerstrokes in the country are running Rotella 15W40.
Arisley is offline
post #3 of 47 (permalink) Old 05-19-2009, 04:38 PM
Re: shell rotella T
I run rotella reg in summer/ syn in winter.
Only difference was easier starting in winter, probably easier on the motor too during warm up when -20F.
I was doing oil analysis with blackstone labs and we came up with a 8,000mile change interval and no difference seen with reg versus syn. I've heard same stories with others as well. So in the summer seems like syn is a waste of money.
Be known. Rotella syn (blue jugs) is one of the only full synthetics out there that is easy to find and reasonably priced,(wallyworld has em) and while it says for diesels it actually is better than most oils. Mobile red cap I believe is a full syn. just costs way more. I learned about rotella oils from sport bike and other performance applications. In bikes where the crankcase shares the clutch oil, the full sys is a must to prevent slipping caused by friction modifiers in most oils.
1994 F-700 Cummins 5.9 12v and Arbortech chip body
1999 International 4900 DT466E w/Allison auto, flatbed 60' rear mount altec am855 boom.
2001 F-350 7.3 4x4 reg cab, single shots, BTS trans,
35" toyo mt's on black 18" KMC addicts
2006 F-350 6.0 4x4 cc lariat, 20" stock wheels with toyo at's....waiting for studs and all that.
frashdog is offline
post #4 of 47 (permalink) Old 05-19-2009, 09:52 PM
SD01WD's Avatar
Re: shell rotella T
Hey Andy! Hi again... How many mile you go between Rotella changes?
2001 SD 2 wheel drive
DP tuned by Scott @ TNT of CC
ITP Regulated Return/ in tank & prepump mods: When Only the BEST will do!
Tank has been harpooned
Gages: Boost and Pressure
on the post & 4" S/S turbo Back by Aljay.
Rancho's all around
SD01WD is offline
post #5 of 47 (permalink) Old 05-19-2009, 10:21 PM
Aint going anywhere fast
blackwaterstroker's Avatar
Re: shell rotella T
Delo is what ive allways ran in my truck...made it a lil quieter I guess...but I have ran rotella a hand full of time cuz of price and It was pretty good aswell...just stay away from castrol...15w40 that chit sucks. I have it in my 6.0 right now and I cant wait to change my oil.
1985 Ford F250 XLT
6.9 IDI
C6
Just bought it!
2003 Harley Davidson EG
True duals, Tuner I love it!!!
2012 Nissan 370Z
___________________________
Past trucks
1995 F250 Powerstroke---sold
2003 F250 6.0-----sold
2008 Chevy LMM Dmax----sold
2007 Ford F-150----Sold
blackwaterstroker is offline
post #6 of 47 (permalink) Old 05-20-2009, 12:52 AM
Re: shell rotella T
You guys make some interesting points. I have a 2002 F350 4x4 7.3 with 77,000 on it. I have tried a few 15w40 oils in the past, but only use the MC oil filter.
I first used the MC 15w40 with no issues (dealer oil changes) but the dealer was getting crazy with the prices. I decided to do the oil changes myself and started using the Rotella 15w40 mainly because of it's popularity with PSD owners. Again, no complaints. I also read many posts where Delo 15w40 was also considered a good oil choice for the PSD. Costco had a sale ( 6- one gallon jugs for $51.00) I purchased (3) cases. My truck seems to like the Delo a little more than the Rotella. Truck seems a little quiter and runs a little better??
I guess the real bottom line is to pick a decent 15w40 that is approved for the PSD as well as decent oil filter and keep the oil and filter changed as required. Just my 2 cents.
bot
BlueOneTon is offline
post #7 of 47 (permalink) Old 05-20-2009, 01:02 AM
diesel and nothing else
amarillo250's Avatar
Send a message via Yahoo to amarillo250
Re: shell rotella T
i run ams-oil 5/40 syn. all year and have the FS2500 oil filter. the oil lab tells me after 10k oil is still like new. The newer engines need the cj4 oil because of the reduced sulfor and older engines run smoother with the rotella because the addits. reduce the soot in the oil.
just something i picked up at the oil lab.
amarillo250 is offline
post #8 of 47 (permalink) Old 05-20-2009, 02:00 AM Thread Starter
Canadian Stroker
doubledoor's Avatar
Re: shell rotella T
what would you say as far as years for older and newer?
4"mbrp turbo back
S&B Intake
WW2,BRV
EBPV delete sensor.
ATS turbo housing
DI up-pipes.
post #9 of 47 (permalink) Old 05-20-2009, 02:29 AM
owner/president
dixieland-diesels's Avatar
Send a message via MSN to dixieland-diesels
Re: shell rotella T
AMSOIL,Ive tried all the rest.just my $.02
03 lariat cc,4x4 7.3,DP-F5,36''MT,8"lift w/trac.bars,4"Silverline ss.exh,AFE II,Optimas,ATS housing,WW,Turbomaster,6.0 IC & tranny cooler,BTS,ISSPRO gauges,HPX,ITP RR,BRV+,Powerslots,WARN prem-hubs,coolant filter,ccv mod,08 mirrors,ARP's,mod.fuel & inj's.,Crower rods,AIH delete,AMSOIL fluids. ~waitn on the 38R~
dixieland-diesels is offline
post #10 of 47 (permalink) Old 05-20-2009, 02:55 AM
All done now
Arisley's Avatar
Re: shell rotella T
I aim for 5K usually make it by 8K. I have been known to go 10K, truck got unhappy there.
As far as Amsoil. What are the ratings on that oil. Not talking about Amsoils ratings, I am talking about API ratings. If it will pass them, why don't they get them?
Arisley is offline
