Schaeffers... - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 05-08-2009, 12:05 PM Thread Starter
jjuddz's Avatar
Schaeffers...
Probably would be fine, but just figured I would ask the masses.. Can I mix the 7000 15w40 with the 9000 5w40??
2002 White CC Short 4x4
Magnaflow Ex
DP-Tuner
jjuddz is offline
post #2 of 11 (permalink) Old 05-08-2009, 02:28 PM
Engineering College Boy
Got Diesel's Avatar
Send a message via AIM to Got Diesel Send a message via MSN to Got Diesel
Re: Schaeffers...
Yeah should be fine.
But how much of each? All it should do is create a blend between the two.
Kyle
Early 99 F-250SD 7.3 PSD 4x4. Auto, tymar type intake, straight pipe, Six inch stacks, Tony Wildman Four position chip, Street race, 80 Tow, 80 Econo, Extreme. Let the smoke roll. Upgraded torque converter. Autometer Ultralights on the Pillar. Running Cooper Discover STT's.
SLAPS MEMBER
Got Diesel is offline
post #3 of 11 (permalink) Old 05-08-2009, 11:00 PM
Freedom is not free
White Buffalo's Avatar
Re: Schaeffers...
Don't do it. You do not want to mix different viscosity oils. In addition, the additive package between the 15W-40 and 5W-40 is different. Since the additives work in conjunction with each other you might be messing up the performance of the oil.
Wher in Oklahoma are you? Just getting ready to move from Fort Sill/Lawton.
White Buffalo is offline
post #4 of 11 (permalink) Old 05-09-2009, 04:02 AM
JHill's Avatar
Re: Schaeffers...
IIRC , on the quart's it said do not mix with other oils, do not see it on the gallon jugs
I switched to the 9000 last oil change after running Rottela 15-40 for
240k+miles.
While I belive Schaffers is a quality oil,I have a issue that was not present before, surges when cold at slow (20-30 mph) in the AM or after sitting for an hour or so.
E '99 F-350 CC LB, ZF6, IDP -T4i Mount, Comp. Fuel System, , Reg. Return, Comp Valve springs, ARP's, DI P- Rods, Adrenaline HPOP, Isspro's, Detroit Tru Trac
238/200
ISM HX50
Tyrant Tunes
South Bend DD
JHill is offline
post #5 of 11 (permalink) Old 05-10-2009, 12:17 AM Thread Starter
jjuddz's Avatar
Re: Schaeffers...
Wher in Oklahoma are you? Just getting ready to move from Fort Sill/Lawton.[/QUOTE]
In Ada. I was wanting to change to the 9000, but I had several quarts of the 7000 leftover, thanks to being only able to buy them in 12's. Dont know why they wont ship them in 15's, since thats what most of these things use...
Magnaflow Ex
DP-Tuner
jjuddz is offline
post #6 of 11 (permalink) Old 05-10-2009, 03:10 PM
Re: Schaeffers...
240k+miles.
That's because of all your horshpowa....
bigjake0524 is offline
post #7 of 11 (permalink) Old 05-10-2009, 08:44 PM
Freedom is not free
Re: Schaeffers...
You might consider buying it by the gallon. Quite a bit cheaper than the quarts.
240k+miles. While I belive Schaffers is a quality oil,I have a issue that was not present before, surges when cold at slow (20-30 mph) in the AM or after sitting for an hour or so.
Wow, I haven't heard of a 7.3L having this issue before. Are you sure it is from the oil and not another issue?
post #8 of 11 (permalink) Old 05-11-2009, 02:45 AM
JHill's Avatar
Re: Schaeffers...
I installed a DIY reg.return 2 days prior and then changed the oil.
not so much an issue as anyoing, fuel pressure does not seem to affect it one way or the other. called and spoke with Jody, should not be a tunning issue
fuel pressure is steady @ 60psi from a rolling start to a wot run, icp/duty cycle are normal. may return the other case for the 7000 and see what happens
238/200
ISM HX50
Tyrant Tunes
South Bend DD
JHill is offline
post #9 of 11 (permalink) Old 05-19-2009, 09:45 PM
hit n miss
Peroni's Avatar
Re: Schaeffers...
240k+miles.
Had the same exact surge problem when I put Rotella 5-40 in the truck. Also switched to 9000 on my last oil change and the problem has not gone away entirely but has got a lot better. Tried a couple ICP's, new IPR, rebuilt IPR, no change. Gunna try 7000 next and see if this goes away. Never did it on Rotella 15-40.
97 Green F-350 XLT 7.3L PSD 4x4 CC LB BTS E40D Manual Hubs 4.10 36000 miles when purchased 4/1/06. Mods - ISSPRO Performax gauges, Tymar intake, Tymar 3x4 DP to 4" ss exhaust, electric fuel, CCV mod, 6.0 fan, tru-cool 4739, Swamps 175/30% injectors, stage I Stealth pump, LASB turbo, Spearco 6.0 cac, live tuned 442hp/860tq.
Peroni is offline
post #10 of 11 (permalink) Old 05-27-2009, 02:06 AM
JHill's Avatar
Re: Schaeffers...
after about 3000 mi it has seemed to go away
238/200
ISM HX50
Tyrant Tunes
South Bend DD
JHill is offline
