X-fer case Lubricant? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 12-12-2013, 12:33 PM Thread Starter
OneTon4Fun's Avatar
I have a 2003 F350 DRW 4x4.
what should I use for transfer case lubricant? What works the best?
OneTon4Fun is offline
post #2 of 4 (permalink) Old 12-13-2013, 11:38 PM
Re: X-fer case Lubricant?
ATF is what is recomended in the transfer case,I just changed my transmission and transfer case to amsoil atf.Its all personal preference what brand to use.
longbowhntr is offline
post #3 of 4 (permalink) Old 12-16-2013, 07:22 PM
MrOneEyedBoh's Avatar
yep. I used the mobil1 syn ATF stuff from Advance Auto. You cna use the same stuff when you flush/swap out your power steering fluid.
MrOneEyedBoh is offline
post #4 of 4 (permalink) Old 12-17-2013, 02:07 AM
International Coal Roller
jbwaldrop88's Avatar
I've always thought that the atf was a little too thin for the chains ans gears in the transfer case, especially if it sees 4x4 alot, we've had alot of good results with adding either Lucas stabilizer or gear oil to the atf to give the chains little more cushion over the sprockets
02 250 CCLB, 6 spd, PHP Phoenix, ISSPROs, AFE/6637 intake, 4" DE straight exhaust, WW, coolant filter with ELC, AIH delete, ebpv delete, bellowed uppies, 4" on 35's and racelines
jbwaldrop88 is offline
