Sea Foam - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 03-22-2009, 06:55 PM Thread Starter
Sea Foam
Anyone use it in your fuel?
Anyone use it in your oil?
Results?
Southpaw is offline
post #2 of 10 (permalink) Old 03-22-2009, 07:21 PM
Super Hauler!
Super_Hauler's Avatar
Re: Sea Foam
we used to have a mechanic run 50% fuel and 50% sea-foam in the fuel bowl, it would clean the injectors really well without pulling them out. You just fill the bowl with with that seam foam then let it fill with diesel and it will run like chit an smoke like a train but it will clean those bugers out!
Super_Hauler is offline
post #3 of 10 (permalink) Old 03-22-2009, 07:26 PM
<----Colin Banks
mattymx's Avatar
Re: Sea Foam
If you use it make sure you drain the water sep out. The alcohol in the sea foam can carry water through the sep and that is not good for the injectors.
mattymx is offline
post #4 of 10 (permalink) Old 03-22-2009, 08:56 PM
Sofa King Cool
BMac's Avatar
Send a message via AIM to BMac Send a message via MSN to BMac Send a message via Skype™ to BMac
Re: Sea Foam
I fill the fuel bowl with it every time I change the filter
People Fly Airplanes, Pilot's Fly Helicopters
2002 F350 Extended Cab Shortbed
1977 Early Bronco
BMac is offline
post #5 of 10 (permalink) Old 03-23-2009, 03:12 AM
look what i can do
1badpsd's Avatar
Re: Sea Foam
1badpsd is offline
post #6 of 10 (permalink) Old 03-23-2009, 08:27 PM Thread Starter
Re: Sea Foam
Maybe I don't understand what you mean. Drain it when?
Also the can says it removes moisture. Is that rue or not?
Thanks for all the replies guys
Southpaw is offline
post #7 of 10 (permalink) Old 03-23-2009, 09:03 PM
Get drunk and be somebody
Holleran's Avatar
Re: Sea Foam
When you change the fuel filter you are suppose to drain the bowl out, because that is where the water sits after it is filtered out of the diesel fuel. It can remove moister because of the alcohol in there, but it may not remove all the water depending on how much is there, and can end up carrying some water threw the injectors, and they will not like that.
You can call me Kyle
My Truck
1997 F-250 7.3L 4x4 Auto
All stock (for now)
222,258miles
The "Other" Truck
1990 F-250 7.3L IDI 2wd Auto
Banks Turbo Charger
EGT and Manifold Pressure gauges
180,000 miles
The Work Truck
1991 F-SuperDuty 7.3L IDI Dully Manual
All stock, and always will be
280,000 miles
Holleran is offline
post #8 of 10 (permalink) Old 03-23-2009, 09:56 PM Thread Starter
Re: Sea Foam
I know that, I do drain the fuel bowl when I change the filter. I was under the impression after reading his post that there was an additional drain you needed to do after adding the sea foam. I guess I read through his post too quick. It sounded to me like I had to drain the sea foam out of the bowl before it went through the injectors.
I'm straight now....Guess I was over-thinking that one....
Southpaw is offline
post #9 of 10 (permalink) Old 04-21-2009, 06:48 PM
woodduck97's Avatar
Re: Sea Foam
What type of sea foam just any kind? Thanks
1997 Ford F-250 Sleeper Edition
woodduck97 is offline
post #10 of 10 (permalink) Old 04-22-2009, 07:52 AM
Grumpy Old Man
Re: Sea Foam
I have used sea foam in my motorcycle fuel for years. It's good stuff but I don't think I would and never have put it in my diesel.
JMHO
Rog
kawa is offline
