UAO-Amsoil, 14K mi - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 02-24-2009, 09:51 PM Thread Starter
Snowman66's Avatar
UAO-Amsoil, 14K mi
Here you go guys. Copper seems to be trending faster to me.
What do you think.
2000 Ecursion 7.3,
Afe stage 1,
Amsoil eng and rear end.
Amsoil bypass
DP Tunrer, 40t, 60e,120,140
FBD 4 in exhaust
Snowman66 is offline
post #2 of 3 (permalink) Old 02-26-2009, 02:08 AM
Freedom is not free
White Buffalo's Avatar
Re: UAO-Amsoil, 14K mi
Copper is a tad high, not exceptionally bad but anything over 40 ppm is considered abnormal. You just reched that limit at 14K so it's not too bad - but you can do better.
The main reason to change this fluid is you are .01 points away from this oil being in the 30 weight range. It is at the very bottom of a 40 weight oil - so in my mind - it's time to change, in addition your oxidation level is at 38 - and 50 is the limit. I would say 10K would be a confortable change interval for your setup with continued oil analysis until you build up some more historical data.
How much fill oil did you add? Looks like calcium got boosted since the last UOA. Which Amsoil bypass system?
Engine looks healthy and your air filter is doing excellent at feeding your engine good clean air (Silicon at 6 ppm).
White Buffalo is offline
post #3 of 3 (permalink) Old 02-26-2009, 06:34 AM Thread Starter
Snowman66's Avatar
I didn't add any oil since last UOA. I don't know how to explaine the increase in additives.
This is my byass setup. I wonder if some of the copper is coming from those brass fittings? I would think if it was bering ware there would be more lead?
http://www.powerstroke.org/forum/99-...ass-cheap.html
2000 Ecursion 7.3,
Afe stage 1,
Amsoil bypass
FBD 4 in exhaust
