RP vs valveline - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 02-11-2009, 07:51 PM Thread Starter
PSDnate's Avatar
RP vs valveline
I ran rp 15w40 for about 70k and switched to valveline prem. blue xtreme 5w40 about 3k miles ago. I tested the rp right before I changed oil. both tests were run right around 3k miles. this was also the first 3k miles that I ran the valveline. this is not a long term test. I will also put up the futher tests that I get done. I have a bunch of fuel in both tests. What could be the cause of this?
D61499.pdf
D66138.pdf
2004 f350 6.0L psd 4x4 6spd cc sb dark shadow gray, sct tuned by eric, 6" ICON 20x12 centerline, 35x13.5 mickey t atz
PSDnate is offline
post #2 of 10 (permalink) Old 02-11-2009, 07:52 PM
<--It Runs Sometimes
justinlw's Avatar
Re: RP vs valveline
You could have one or more injectors failing.
2004 King Ranch F250 FX4 6.0L
5" Lift with 35x13.50R18's
Stage 1's by Josh Davis, FASS 150/[email protected]
CCV Re-route, EGR Delete, Throttle Plate Delete, Banks Monster 4"-5" Tip
justinlw is offline
post #3 of 10 (permalink) Old 02-12-2009, 10:36 AM Thread Starter
PSDnate's Avatar
Re: RP vs valveline
wouldn't I notice that in the performance of the truck? The truck runs fine.
PSDnate is offline
post #4 of 10 (permalink) Old 02-12-2009, 12:51 PM
justinlw's Avatar
Re: RP vs valveline
It depends. I thought mine ran fine until I replaced 2 of the failing injectors. Then I realized it was running like crap before. The only link between fuel and oil is the injectors.
justinlw is offline
post #5 of 10 (permalink) Old 02-12-2009, 10:21 PM Thread Starter
PSDnate's Avatar
Re: RP vs valveline
so how did you figure out that your injectors were bad?
PSDnate is offline
post #6 of 10 (permalink) Old 02-14-2009, 02:15 PM
Freedom is not free
White Buffalo's Avatar
Re: RP vs valveline
Attachment 4702
Attachment 4703
Nate, on your first UOA Blackstone failed to inform you that your viscosity dropped down to the lower 1/3 range of a 30 weight oil. A 40 weight oil should fall between 12.5 - 16.29 cSt Viscosity @ 100C (in the properties section of your UOA report). Your viscosity is at 10.8 - a 30 weight oil ranges from 9.3-12.49 cSt Viscosity @ 100C. The 6.0's shear oil quicker than the 7.3L's.
Your second UOA running Valvoline shows the viscosity dropping even lower. The fuel level is increasing and could be part of the reason for the viscosity drop.
White Buffalo is offline
post #7 of 10 (permalink) Old 02-14-2009, 02:30 PM Thread Starter
PSDnate's Avatar
Re: RP vs valveline
thanks for the info buffalo. I think I need to take it some where to get this fuel problem takin care of.
PSDnate is offline
post #8 of 10 (permalink) Old 02-15-2009, 01:45 AM
Freedom is not free
Re: RP vs valveline
Wear metals (Iron, Copper, Lead, Alum, Chromium) look great Nate - a great example/comparison showing how overpriced Royal Purple is. Even though it has some Molybdenum in it, RP doesn't use as much as Delo 400 and less than 1/2 that Schaeffer's uses and charges alot more for their product.
post #9 of 10 (permalink) Old 02-23-2009, 05:10 PM
PGreenSVT's Avatar
Re: RP vs valveline
I immediately picked that up as well and was going to say something till I saw your post. What I find particularly disturbing is that Blackstone suggests it is ok to run this oil longer. What are they thinking? I'd like to see another run with the valvoline after you get the injector problem straightened out. It certainly looks like there is a problem there.
Deceased Member RIP Mitch the PSN crew
05 F250 Harley Davidson long bed, Airaid CAI, CFM+ Largemouth in CF with pipe kit, zoodad mod, 4" turbo back Magnaflow duals with kitty delete and 6" tips, Edge Insight monitor with EGT, SCT with tunes by Eric; DJ's billet oil filter cap feeding a Gulf Coast bypass filter, 275/65/20 Nitto Terra Grapplers, 03 turbo whistling a happy tune.
PGreenSVT is offline
post #10 of 10 (permalink) Old 02-23-2009, 11:08 PM Thread Starter
PSDnate's Avatar
Re: RP vs valveline
the trucks in the shop this week. when I get it back I'll change the oil and test it after another 3k.
PSDnate is offline
