best fluid for a tired ZF - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 08-07-2013, 01:51 PM Thread Starter
jbrixen's Avatar
i am planning on rebuilding the tranz but will most likely not happen until spring. the syncros are getting bad, it is not as bad in the morning when the fluid is cooler. i am going to change the fluid and wanted to know if i should run something different than syn ATF. i live in the north western part of WI, so it will be seeing sub zero temps, what are your recommendations for fluid. and it has just over 500 miles on a new clutch.
jbrixen is offline
post #2 of 6 (permalink) Old 08-07-2013, 03:58 PM
CGMKCM's Avatar
Re: best fluid for a tired ZF
Full disclosure, I do not have a hand shaker in my truck.
I shifted my 02 VW golf TDI to Pennzoil synchro (available at Advance Auto Parts) at 200k and have been running it for >20k miles.
My VW Guru told me about it and I bought a couple of bottles and changed over. My shifting has improved dramatically and no gear grinding.
Pennzoil developed the fluid for G.M. manual transmission.
The Chevy and Dodge guys are using it in there hand shakers and love the results. I have not read anything negative about it.
[SIGPIC][/SIGPIC]
2001 F-550 4X4 Lariat
BTS Tranny
PHP Phoenix chip
H2E Turbo With WW II
Adrenalin
Banks Intercooler and exhaust
In tank and pre-pump mods
Numerous minor Mods
Other Diesels
08 GL 320 CDI
02 VW Golf TDI
3054 Kioti Tractor
Kubota ZD 323
CGMKCM is offline
post #3 of 6 (permalink) Old 08-07-2013, 08:28 PM Thread Starter
jbrixen's Avatar
i have debated trying the syncromesh that amsoil offers for the GM's. when i worked at napa thats what all the import guys wanted in there ""race cars"".
jbrixen is offline
post #4 of 6 (permalink) Old 08-09-2013, 01:48 AM
Got Smoke?'s Avatar
I just installed a solid flywheel & south bend clutch in my truck last week. I took the opertunity to drain my ZF5 and refill with Amsoil Signature Series ATF, and it seems to shift a lot better than before at 201,000 miles. Next up is the heim joint clutch linkage fix this weekend!
1997 F350 6pos , 3" DP 4" straight, SBC clutch, Auto Meter Gauges, Irate bellowed up pipes, WW2, 1.0, Intercooled, TS 6 position chip, Amsoil 4510 CAI.
[/URL]
Got Smoke? is offline
post #5 of 6 (permalink) Old 08-09-2013, 02:29 AM
salprofish's Avatar
I cant remember who, but someone on this board is running Redline atf and he said it really made a night and day difference with the syncros grinding.
97 250 EC 4x4
5 speed
6637 Napa Filter
ccv mod
3" diamond eye dp
175cc 80% over Rosewood inj.
Custom tuning by Cale Thompson
4" Rough Country Lift
315-70-17 BFG AT Tires
Rebuilt zf5 at 250000
my new favorite gun:
LAR grizzly 50 BMG big boar
salprofish is offline
post #6 of 6 (permalink) Old 08-09-2013, 02:51 PM
International Coal Roller
jbwaldrop88's Avatar
My syncros weren't grinding but im running a quart 140 gear oil in mine, it thickens it up to about like syncromesh, some people will tell you only run atf but the chevy zfs are built to run syncromesh and I have never seen anything showing that the materials are different ford and chevys
02 250 CCLB, 6 spd, PHP Phoenix, ISSPROs, AFE/6637 intake, 4" DE straight exhaust, WW, coolant filter with ELC, AIH delete, ebpv delete, bellowed uppies, 4" on 35's and racelines
jbwaldrop88 is offline
