schaffer oil - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 02-10-2009, 06:37 PM Thread Starter
JHill's Avatar
schaffer oil
met with a sales rep last week, seems like pretty good stuff.
I am leaning towards the 9000 full syn. with pulling season getting closer.
any reason not to? bear in mind I have 289k on the clock.
I have ran Rotella 15/40 and Rotella Syn 5/40 in the winter months since i bought the truck
on edit: the price differance is .43/qt than the 7000 Blend
E '99 F-350 CC LB, ZF6, IDP -T4i Mount, Comp. Fuel System, , Reg. Return, Comp Valve springs, ARP's, DI P- Rods, Adrenaline HPOP, Isspro's, Detroit Tru Trac
238/200
ISM HX50
Tyrant Tunes
South Bend DD
JHill is offline
post #2 of 5 (permalink) Old 02-14-2009, 01:34 PM
Freedom is not free
White Buffalo's Avatar
Re: schaffer oil
Both are very good oils with high viscosity indexes and both have 0% on all 3 foam sequence tests.
9000 (5W-40) VI = 159
7000 (15W-40) VI = 154
So, both will resist shearing very well. What is your HPOP setup? This would be one of the areas I would focus on if I was you Schaeffer's rep. Some 7.3L's will dual HPOP setups can shear the viscosity quicker than single HPOP setups.
The technical data sheet comparison shows:
http://www.schaefferoil.com/datapdf/700.pdf
http://www.schaefferoil.com/datapdf/9000.pdf
The 7000 on average runs a tad bit higher viscosity, but not by much and the 9000 will yield better cold starts.
Depending on how crazy you want to get, you can ask your rep to run a Used Oil Analysis (UAO) on your truck after using each oil at the same interval and then you will have some hard data for a comparison.
My 2 cents:
White Buffalo is offline
post #3 of 5 (permalink) Old 02-14-2009, 06:02 PM
Re: schaffer oil
I'm using the 7000 love it!!
F-350 is offline
post #4 of 5 (permalink) Old 02-15-2009, 02:30 AM Thread Starter
JHill's Avatar
Re: schaffer oil
Stock 15* pump , the Dieselsite Adreneline pump looks like a good option
the rep sent to sample copies to compare with Blackstone Reports
238/200
ISM HX50
Tyrant Tunes
South Bend DD
JHill is offline
post #5 of 5 (permalink) Old 02-20-2009, 02:15 AM
Re: schaffer oil
I have been running Amsoil and I have been noticing a very rough idle. Is this somthing that could be coming from the oil?? Which oil should I be running?
2001 White F250 4X4 Extened Cab, BTS Transmission & Converter, H2E Turbo, Stock Injectors, BTS tunes, 80Tow, 100Tow, 120Race, 140Aggresive, Terminator, ITP reg return, 6.0 Intercooler, 6.0 Trans Cooler, AFE Stage II Intake, Boost regulator, CCV Mod, Zoo Dad Mod, Guages, 4" Exhaust, 3" Lift and 35" BF TA's.
Sledhead F250 is offline
