Delo 15w40 - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 02-04-2009, 12:24 AM Thread Starter
HHAUL'N STROKER
SMOK'N BLUE STROKER's Avatar
Delo 15w40
Anyone here use Delovac 15w40 here?
SMOK'N BLUE STROKER is offline
post #2 of 11 (permalink) Old 02-05-2009, 12:47 AM
Freedom is not free
White Buffalo's Avatar
Re: Delo 15w40
Delo 400 15W-40 is a very good oil for a PSD. Very good results on Used Oil Analysis Reports, If I didn't run Schaeffer's Oil I would use Delo 400.
White Buffalo is offline
post #3 of 11 (permalink) Old 02-05-2009, 01:24 AM
psdmike's Avatar
Re: Delo 15w40
I use it. Seen it today at WallyWorld it went up about a 1$ a gallon from a couple weeks ago.
1997 F350 Crew Cab, 7.3, 4x4, 5SP Short Shift kit, 5" RSK SD V Code springs, DIY Intake, 5" Exhaust with 30" FTE Resinator, intercooled, TS chip.
psdmike is offline
post #4 of 11 (permalink) Old 02-05-2009, 08:15 PM Thread Starter
HHAUL'N STROKER
Re: Delo 15w40
Yea thats what i use now and I love it! Engine seems to like it! Anyone else out there use it?
post #5 of 11 (permalink) Old 02-05-2009, 11:37 PM
tkdbf350's Avatar
Re: Delo 15w40
I use it in my personal and we run it in all the diesels at work never had a problem.
2006 F350 CC/LB Lariat FX4, MBRP 4in
2003 F350 standard cab DRW 6spd FX4, aFeII, straight piped duals, DP Tuner Stock, 60T, 80E, 140 Agg, BDP 160cc singles, SBC, ISSPRO A-Pillar gauges boost and egt, ITP Overboost Annihilator, 1.00 Ex. Housing, Wicked Wheel, ITP Pre-pump/In-tank Kit, A/C valve, coolant filter.SOLD
tkdbf350 is offline
post #6 of 11 (permalink) Old 02-06-2009, 02:37 AM
Freedom is not free
Re: Delo 15w40
One of the reasons I prefer Delo 400 over Rotella is it's additive package. Delo 400 uses Moylbdenum like Schaeffer's does - just in a smaller amount. Here are two oil analysis reports to show my point. The first is a virgin oil sample of Rotella 15W-40. The second is of Delo 400 15W-40. Looking at the additive levels on the reports, you can see the difference in the additive packages.
Unfortunately the Delo 400 report I posted is not of a virgin sample but I think it will sufice to show my point - even though the additive levels are lower than a virgin sample. I thought I had a Delo 400 virgin sample on my laptop at home, it must be on the work one.
post #7 of 11 (permalink) Old 02-06-2009, 03:07 AM Thread Starter
HHAUL'N STROKER
Re: Delo 15w40
At my work for services on all semis and such we use delo. And we service alot of the big oil companies trucks like Schlumberger,BJ,Halliburton etc and they all prefer and request that delo gets used in all their trucks. And if any of you are familiar with frac pumps we service those to and use delo in those to. Id say its a pretty trusted oil!
post #8 of 11 (permalink) Old 02-06-2009, 04:58 AM
bigd4me2's Avatar
Re: Delo 15w40
smokin/blue,
I have the same experience with delo. I have worked for 4 companies with good sized fleets over the past 25 years, all of them used delo 15-40. if you are in a very cold climate I would strongly consider synthetic but, there is nothing wrong with delo. I have used it for 20 years but, I'm in a warm climate.
I do believe IH factory fills, and suggests delo! that is saying something! I would not hesitate to use mobile delvac, that would be my next choice.
02 dmax cc dually 4wd "miss piggy" tow bitch, afe pr7, magnaflow, Kennedy lift pump, dual rail mount filters, PPE tunes
00 f350 srw rc=6100lbs
ats comp housing,bdp 1.0 exhaust,afe pr7,4in turbo back magnaflow,hx cross,di regulated return,bbha,dp hi,40,80e,120r,6.oh no cooler autometer gauges, dual rail mount filters
bigd4me2 is offline
post #9 of 11 (permalink) Old 02-07-2009, 04:37 AM Thread Starter
HHAUL'N STROKER
Re: Delo 15w40
Originally Posted by bigd4me2 View Post
smokin/blue,
Alot of new Petes with CATS and CUMMINS in them come factory filled with delo to. At least they have the sticker that says so on them!
post #10 of 11 (permalink) Old 02-07-2009, 04:06 PM
Re: Delo 15w40
All my logging buddies here in Idaho use Delo in their logging trucks. There's nothing worse on a diesel engine than running a logging truck in these mountains and talcum dust. I have some blackstone reports from when I was running Amsoil and then switched to Delo, very dramatic difference.
pappy19 is offline
