UOA...Where should I send my oil? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 14 (permalink) Old 01-20-2009, 02:34 PM Thread Starter
GilroyRacing's Avatar
I am due for a oil change in another 1,000 miles or less and I want to send it out to get checked. I have been using BlackStone, but have heard some bad about them lately.
Where would you suggest I send the oil out to??
96FordF3507.3PSDCC, (Line X'd) bed, 4x4, 5 speed manual, 4.11 gears, 285/75/16 Cooper Discoverer ATP , 260,000 miles, 3-4" down pipe, 4" exhaust w/5" polished SS tip, gutted EBPV, chrome nerf bars, autometer ultra lite pyro and boost gauges, alpine cd player, alpine speakers, Garmin GPS.
"Real trucks have 3 Pedals, 2 Sticks, and No Spark Plugs"
GilroyRacing is offline
post #2 of 14 (permalink) Old 01-20-2009, 04:07 PM
Edward Scissorhand WanaB
Bushwakd's Avatar
Re: UOA...Where should I send my oil?
Someone just posted in this thread about lab testing https://www.powerstrokenation.com/for...483#post363483
"Real Trucks Don't Have Sparkplugs"
2000 F-250 Lariat, CC, 4x4, LWB,
A few mods to make it better than stock.
250cc hybrids, Stealth stage II HPOP, H-11 Headstuds, Strickly Diesel Reg. Return Fuel, Spearco 6.0 IC, Garrett 38r 1.15 hsg, BTS transmission, Gearhead Tuning
"The Smoke Don't Mean Its Broke"
Bushwakd is offline
post #3 of 14 (permalink) Old 01-22-2009, 01:50 AM
<----My last CT scan
Motownfire's Avatar
I have sent a few samples here http://www.blackstone-labs.com/ for UOA.
Motownfire is offline
post #4 of 14 (permalink) Old 01-22-2009, 03:45 AM Thread Starter
as mentioned above....
post #5 of 14 (permalink) Old 01-22-2009, 03:47 AM Thread Starter
That link woulnt work...
post #6 of 14 (permalink) Old 01-22-2009, 05:04 AM
May want to give Schaeffer's a try. I'll pm you a member here to contact.
'95 F250 Extended Cab E40D 2WD
IDM MOD - HPX -
dzlstroker is offline
post #7 of 14 (permalink) Old 01-22-2009, 01:37 PM
Motownfire's Avatar
Question Re: UOA...Where should I send my oil?
What bad stuff have you heard???
post #8 of 14 (permalink) Old 01-23-2009, 11:17 AM
Freedom is not free
White Buffalo's Avatar
Can't beat Schaeffer's. At $9 a piece and postage is prepaid to send the sample to the lab.
In addition, Schaeffer's and OAI Testing also provide the nitration & oxidation levels which Blackstone does not.
White Buffalo is offline
post #9 of 14 (permalink) Old 01-25-2009, 05:16 AM
Needs more hours per day
jtharvey's Avatar
Several errors and inconsistencies in their reporting, in reports from several different people. I've seen several of them. Things like coolant leaks in one report that seems to have magically disappeared in the next one with nothing done to the engine, reporting significant PPM of metals in an oil that simply can't be there (magnesium, which is an additive, but the gear lube sampled doesn't use any of it), and numbers that just don't make sense with increases in viscosity over time while TBN goes down and no significant soot (excessive soot can increase viscosity)...just to name a few.
Too many reports from them, all from different people, and over the last couple of years. I just don't trust them anymore. The majority of the time, Blackstone seems fine, but I won't risk it with them anymore.
I started using Schaeffer's because of that, and have been very pleased with the service there. Schaeffer's reports are a little more "raw" than Blackstone since they don't have the little narrative at the top, but the data is all there, including a couple things Blackstone doesn't test for.
Like Rich pointed out too, the price is significantly less expensive. At $9 a sample for Schaeffer's kits, you can get nearly 6 samples from Schaeffer's for what it would cost for only 2 from Blackstone.
Jeremy
2000 F-350, CCLB, SRW, 4x4, '04 5.9 Common Rail Cummins Conversion
F1 sticks, Evil Twins Dual CP3's, F1 Springs, Helix 2 Cam, ARP headstuds, ED Turbo, Smarty, BTS Trans
Eventually: Compound Turbos
jtharvey is offline
post #10 of 14 (permalink) Old 01-30-2009, 09:20 PM
Fat Kids Rule!
House's Avatar
Send a message via AIM to House
http://www.polarislabs1.com/
Joe "House" Kupferschmid
1995 F250 7.3 2.6 zf6 Puller
2006 Chevy 3500 CC DRW LBZ, Tow Slut
SOLD:2000 F350 harvester of sorrow
House is offline
