Liqui-Moly 5w40 - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 12-24-2008, 09:46 PM Thread Starter
qcfarmer's Avatar
Send a message via Skype™ to qcfarmer
Liqui-Moly 5w40
My local autoparts carries this brand of Syn for diesels (mostly VW's) Is it O.K. for PSD? If you google it, you can get the spec sheets but I don't know what to really look for.
2008 F-450, 6-spd, Spartan DD, Powerstroker67 DPF/CAT delete.
1997 F-250 PSD, SB Ex Cab, 5 spd, Open intake, 3" downpipe, 5" single turnout stack, DIY Stage 1's, T.E. modded HPOP, Tuned by Tony, 4" lift, D60- SOLD
qcfarmer is offline
post #2 of 4 (permalink) Old 12-24-2008, 09:47 PM
<----Colin Banks
mattymx's Avatar
Re: Liqui-Moly 5w40
What are the specs for that oil? If it meets the same specs, then it should be OK.
mattymx is offline
post #3 of 4 (permalink) Old 12-25-2008, 05:53 PM Thread Starter
qcfarmer's Avatar
Re: Liqui-Moly 5w40
http://www.liqui-moly.de/liquimoly/mediendb.nsf/gfx2/1340%20Diesel%20Synthoil%20SAE%205W-40_EN.pdf/$file/1340%20Diesel%20Synthoil%20SAE%205W-40_EN.pdf
spec sheet
qcfarmer is offline
post #4 of 4 (permalink) Old 12-25-2008, 05:54 PM Thread Starter
qcfarmer's Avatar
Re: Liqui-Moly 5w40
Diesel Synthoil
SAE 5W-40
DESCRIPTION Diesel Synthoil SAE 5W-40 is a fully synthetic high-performance, low-friction
engine oil designed for year-round use in passenger motor vehicle diesel engines.
Optimum engine oil for aspirated diesel engines and diesel engines with exhaustgas
turbocharging, with and without charge air cooler and direct fuel injection. The
synthetic base oils and high proportion of additive components satisfy and exceed
the requirements of the most state-of-the-art engine designs.
PROPERTIES - smooth engine running
- rapid oil delivery at low temperatures
- very high lubrication reliability at high and low temperatures
- very high shear and ageing stability
- very good wear protection
- extremely low evaporation losses
- outstanding engine cleanliness due to high dirt suspending power
- tested with catalytic converters and performance proved with turbochargers
- optimum oil pressure at all engine speeds
- measurable oil and fuel savings, reduced pollutant emission
- miscible and compatible with commercially-available engine oils.
Specifications / Approvals
API CF
ACEA B3-98 Issue2/B4-98
VW 502 00, 505 00
BMW Longlife-98
Mercedes Benz 229.1, 229.3
TECHNICAL
DATA Viscosity class : 5W-40
ASTM colour : 3
Density at 15 C : 0.85 g/cm
Viscosity at 40 C : 87.3 mm/s
Viscosity at 100 C : 14.1 mm/s
Viscosity index : 138
Flash point : 193 C
Pour point : -42 C
…/2
APPLICATION Optimum oil for aspirated and turbo diesel engines with and without charge air
cooling. Especially suitable where there are long intervals between oil changes and
extreme engine requirements.
INSTRUCTIONS The operating instructions of the vehicle and engine manufacturers must be
followed.
AVAILABLE
PACK SIZE Diesel Synthoil SAE 5W-40 1 l Part no. 1340
5 l Part no. 1341
PI 07/
qcfarmer is offline
