first oil change ?'s - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 12-16-2008, 02:19 AM Thread Starter
I am getting ready to do the first fluid change in my truck, I plan on using the schafers 9000 5w-40. Will there be a problem switching to synthetic when it mixes with the oil thats left in the motor? My truck has 140k on it. What do yall recomend for the trans, transfer case, and the diffs?
1997 F350 CC/LB 4x4, 5 spd., 6 pos. chip, 3" exhaust, 6" lift on 37's, 04 king ranch interior
noshoes is offline
post #2 of 4 (permalink) Old 12-16-2008, 04:09 PM
PSN Mega Miler
crowz's Avatar
Re: first oil change ?'s
All I did was the normal draining of the oil and adding 5w40 valvoline synthetic. No problems here. Just change it like normal and the synthetic should do fine.
2002 F250 SuperDuty Lariat PSD 7.3 Crew Cab 4x4 302,000+ miles.
, Valvoline Extreme Blue 5w40 Synthetic,
, Clifford Matrix 50.5x Alarm
, P3 Brake Controller, Swamps Injectors, PHP Tunes
crowz is offline
post #3 of 4 (permalink) Old 12-16-2008, 11:18 PM
It will obviously get diluted, but after a few more changes you can be sure you'll be 100% to whatever you're putting fresh in there.
TheDirt is offline
post #4 of 4 (permalink) Old 12-17-2008, 02:08 AM Thread Starter
Thanks, that is what I needed to know. What do yall recommend for the diffs and such?
noshoes is offline
