A Couple Fuel Additive Questions - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 11-28-2008, 12:59 PM Thread Starter
I see on this forum that some of you are using 2 stroke oil in your fuel. Whats the ratio? Are you running it because it's cheaper than the off the shelf additives? I get that we have to run something in our fuel because of the ultra-low sulfer fuel now, and the lubrication qualities are almost non existant. I personally use Racor Powershot' and Racor Performance Plus, at the same time, because I like the added cetane boost[power], and the improved fuel economy. But I am curious about using 2 stroke oil, and is there any other additive I should think about running instead? Thanks
Barry Tislow is offline
post #2 of 9 (permalink) Old 11-28-2008, 11:47 PM
PSDnate's Avatar
Re: A Couple Fuel Additive Questions
1oz 2 stroke oil to a gal. of fuel
2004 f350 6.0L psd 4x4 6spd cc sb dark shadow gray, sct tuned by eric, 6" ICON 20x12 centerline, 35x13.5 mickey t atz
PSDnate is offline
post #3 of 9 (permalink) Old 11-29-2008, 12:00 AM
CLARKY
smokinndstrokin's Avatar
X2 on the 2 stroke oil, 1oz of Ashless 2 stroke-1gal of fuel.Works good IMO!
2001 F350 SD K&N intake tube w amsoil filter nd prefilter,4in turbo back to 6in tip,TS chip,,isspro guages(poost,pyro,trans)AIH delete,CCV, Dr.evil trans w 3 disk lock up converter by Hughes,wicked wheel,Mag hytec covers with many more mods to come
smokinndstrokin is offline
post #4 of 9 (permalink) Old 11-29-2008, 01:22 AM
Cute and cuddly boys!
mazdaparts's Avatar
Send a message via Yahoo to mazdaparts
I used the walmart brand because it was like $9 a gallon. I stopped using it and can tell a difference. I used it and the Motorcraft cetane boost. Ran out of 2 stroke oil and just haven't bought any, but I still use the Motorcraft cetane boost. It definitely added lubricity as the injectors seems quieter. But I think my fuel mileage and performance suffered a little. Now that the 2 stroke is out of my system it seems like the truck is more peppy. Could be from the oil lowering the btu of the fuel, but then I'm no smart guy like some of these guy here.
2002 F250 Crewcab Shortbed 4X4 Totaled 6/16/12
2000 Expedition Eddie Bauer 4x4
There are 2 rules to getting ahead.
Rule #1. Don't tell anyone everything you know.
mazdaparts is offline
post #5 of 9 (permalink) Old 11-29-2008, 02:16 AM
I would tend to agree with you. I have not used 2 stroke oil yet. I was wondering if it would affect fuel burn. Looks like it does. I'm thinking No. We're in it to make power, not throw it away.
OBS96 is offline
post #6 of 9 (permalink) Old 11-29-2008, 07:02 PM
PSDnate's Avatar
a lot of guys claim to get an increase in mpg using 2 stroke oil. Up to 2 mpg. I have been using it for awhile and I havn't seen a diff in mpg.
PSDnate is offline
post #7 of 9 (permalink) Old 11-29-2008, 11:42 PM
CLARKY
I havent noticed a mpg diff, maybe 1mpg more.But how it quieted the injectors is really nice.
post #8 of 9 (permalink) Old 11-30-2008, 12:35 AM
matthewd11's Avatar
You should see a bit MORE BTU with the oil, and it should run a little hotter.
Oil will combust and produce energy. You are basically adding a second fuel in the mix.
I noticed a jump in fuel mileage with the 2 stroke oil and the injectors are much quieter.
I dont see how it would lower the BTU per burn
matthewd11 is online now
post #9 of 9 (permalink) Old 12-06-2008, 04:56 AM
I'm going to try it in a tank or two. I'll see how it works for me.
OBS96 is offline
