Oil testing - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 17 (permalink) Old 11-27-2008, 03:48 PM Thread Starter
PSDnate's Avatar
Oil testing
Where and how do I get my oil tested? How oftern do you guys get yours tested.
2004 f350 6.0L psd 4x4 6spd cc sb dark shadow gray, sct tuned by eric, 6" ICON 20x12 centerline, 35x13.5 mickey t atz
PSDnate is offline
post #2 of 17 (permalink) Old 11-28-2008, 02:20 AM
Re: Oil testing
Blackstone Labs
Natch02 is offline
post #3 of 17 (permalink) Old 12-01-2008, 02:40 AM
Doakster's Avatar
Re: Oil testing
They will sent you a free sample kit.
I did my first on my last oil change(5000 mile), and I plan on doing my next at 6000 miles when I change the oil again.
My TBN, Total Base number, what very good meaning that the oil has not become acidic and the life of the oil can be extended.
They will give you a written recommendation based on your results as well.
2003 F-350 4x4 SC 7.3, WOP QSSB Turbo, Isspro Gauges, MBRP 4 inch, AFE Stage II, , DP Tuned Stock, HI, 40t, 60t, 80t, 80e, 120R, 140ex, 6.0 Trans Cooler, 08 Tow Mirrors, 35in Kumho Mts
1993 International 4600 Dump, 7.3 IDI
Doakster is offline
post #4 of 17 (permalink) Old 12-01-2008, 05:51 AM
Needs more hours per day
jtharvey's Avatar
Re: Oil testing
If you've got a Schaeffer's rep near you, their test kits are only $9 and postage is pre-paid. You do have to pay for the kits upfront though. However, at under 1/2 the cost of a Blackstone kit (almost 1/3 once you add in postage you have to pay with Blackstone), it's worth it, IMO.
I sample my oil at every drain, unless I'm going for an extended drain interval, then I'll sample a little bit between changes, at every 4K-5K.
Jeremy
2000 F-350, CCLB, SRW, 4x4, '04 5.9 Common Rail Cummins Conversion
F1 sticks, Evil Twins Dual CP3's, F1 Springs, Helix 2 Cam, ARP headstuds, ED Turbo, Smarty, BTS Trans
Eventually: Compound Turbos
jtharvey is offline
post #5 of 17 (permalink) Old 12-01-2008, 11:12 AM Thread Starter
PSDnate's Avatar
Re: Oil testing
I aready ordered blackstones kit. I pre paid for the 6 pack. Thanks for the info though. I'll have to look into that after I use the stuff from blackstone.
PSDnate is offline
post #6 of 17 (permalink) Old 12-01-2008, 11:15 AM
Funrunner99
funrunner99's Avatar
Re: Oil testing
Any hints on finding a Schaeffer's rep?? I am in the Sacramento, CA area.
1997 F350 Regency Crew Cab Dually 7.3, Auto with Baumann deep finned aluminum pan, K&N filter, DJM 3" front drop Dream Beams & rear hanger & shackle kit, 3" downpipe, 4" MBRP Single Exhaust out to 5" tip. 3 pod pillar mount with Autometer Pyro, Trans Temp & Boost guages.
TT 306, Tremec TKO 600 5 spd, lots of fun!
funrunner99 is offline
post #7 of 17 (permalink) Old 12-01-2008, 04:11 PM
jtharvey's Avatar
Re: Oil testing
Best bet it to call their home office and ask for a rep closest to you. Make sure you specify that you need a rep, and not a retail location. Their number is Toll Free: (800) 325-9962, from their website. http://www.schaefferoil.com/
Jeremy
jtharvey is offline
post #8 of 17 (permalink) Old 12-02-2008, 02:56 AM
Funrunner99
Re: Oil testing
Thanks for the info JT, will look into that. Bought my '97 truck with only 63K on it earlier this year which I hope will turn out to be a good thing. But I have had to replace a couple items that seemed a little unusual for a low mileage vehicle. Not everything on these trucks, or any vehicle I guess like to sit around too much! Think I will check the oil just to be safe. Why do you guys do it so often though??? Every oil change seems a little over the top?? But if it's only $10 or so I guess it might save some $$ down the road if you caught something.
post #9 of 17 (permalink) Old 12-02-2008, 03:35 AM
Doakster's Avatar
Re: Oil testing
Wait you ordered blackstones test kits and paid for them? I requested they send me two kits when I sent my sample in, a week went by and nothing came and I happened to call them, while I was on the phone I requested two more.
A few days later I had four kits in my hand, and I still do right now, all for free
Doakster is offline
post #10 of 17 (permalink) Old 12-02-2008, 05:27 AM
jtharvey's Avatar
Re: Oil testing
It probably is over the top, but I just like to know what's going on at all times with the engine. It helps to establish trends so if the readings start to change, I'll have something to compare it to. It can also help to catch a problem before it might get out of hand, like finding fuel dilution or coolant in the oil. May not be showing any signs of it while running, but things could be starting to go wrong and you could catch it before major damage is done.
Blackstone does offer the option to pre-pay for their kits. Most just opt for the free kit though and pay for it when the sample is sent in.
Jeremy
jtharvey is offline
