Trans, Transfer, and Diff Fluids - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 13 (permalink) Old 11-27-2008, 02:58 PM Thread Starter
mbg75's Avatar
Looking to change the trans, transfer, and diff fluids. I'd like to go synthetic, anyone have a link or info to types, weights, and amount needed?
thanks!
mbg75 is offline
post #2 of 13 (permalink) Old 12-04-2008, 02:36 AM
bigd4me2's Avatar
Re: Trans, Transfer, and Diff Fluids
rear diff, just fill it up till its coming out the fill plug. i pulled my leaking pan and resealed it, and mine took about 3 1/2 quarts. royal purple 85/140? or close to that, with no friction modifier. "this is for a 10.5 sterling" not a d-80
mobil 1 is fine, ams, or Shaffer's. pick your poison, i'm just using dex-3/mercon dino in my ford.
Trans holds about 16 to 18 quarts when it is rebuilt i believe, or bone empty!
7 to 8 with just a pan change, and filter.
i would plan on 5 or 6 gallons so you will have some left over. and do the hoot method flush on the trans, otherwise you will just be mixing fluids. i just did the hoot on my dmax, and i used 5 gallons even. did a hoot on the ford a long time ago, used about the same. how many miles is on your trans?
i do not have a transfer case, or a ft diff on the ford, but usually you fill them till fluid is coming out the fill hole.
the ft diff should take 2 to 3 quarts. i think 75/90 is ok for the front. the t case, i really don't know, but my d max holds about 2 1/2 quarts.
02 dmax cc dually 4wd "miss piggy" tow bitch, afe pr7, magnaflow, Kennedy lift pump, dual rail mount filters, PPE tunes
00 f350 srw rc=6100lbs
ats comp housing,bdp 1.0 exhaust,afe pr7,4in turbo back magnaflow,hx cross,di regulated return,bbha,dp hi,40,80e,120r,6.oh no cooler autometer gauges, dual rail mount filters
bigd4me2 is offline
post #3 of 13 (permalink) Old 12-04-2008, 02:38 AM
Super Hauler!
Super_Hauler's Avatar
trans is only 6 quarts in manual tranny
Super_Hauler is offline
post #4 of 13 (permalink) Old 12-04-2008, 02:57 AM
bigd4me2's Avatar
thank's, i just azzumed it was an auto. no need to do a hoot flush if the truck has a manual trans.
bigd4me2 is offline
post #5 of 13 (permalink) Old 12-04-2008, 02:59 AM
King Dingaling
TANK'S 250's Avatar
Cooling System 27.5 Quarts (26.0 Liters)
Engine Oil 15.0 Quarts (14.2 Liters)
Fuel Tank F-350 Long Bed 38.0 Gallons ( 143.9 Liters)
Transfer Case 2.0 Quarts MERCON ATF
Automatic Trans mission fluid including remote filter change. 17.5 Quarts
manual tranny 6 quarts
diff fluid 2.4 quarts 75w 90 or 75w-140
TANK'S 250 is offline
post #6 of 13 (permalink) Old 12-04-2008, 03:04 AM
bigd4me2's Avatar
tank, 2.4 quarts for the rear, or the front diff?
bigd4me2 is offline
post #7 of 13 (permalink) Old 12-04-2008, 03:18 AM
King Dingaling
TANK'S 250's Avatar
dunno,...can't seem to locate my FORD CD's,...I was just going from memory.
I must have lent them out to someone.
post #8 of 13 (permalink) Old 12-04-2008, 08:24 AM
BUFF's Avatar
IIRC the 10.50 rear is 4qt. My mag-hytec cover makes its 6qt.
06 F350 CC LB 4x4 with a few odds and ends
BUFF is offline
post #9 of 13 (permalink) Old 12-04-2008, 12:00 PM
Village Idiot
LRTMatt's Avatar
You should have a little bit left out of 4 quarts for the 10.50. Make sure it is synthetic as recommended by Ford.
LRTMatt is offline
post #10 of 13 (permalink) Old 12-05-2008, 03:19 AM Thread Starter
mbg75's Avatar
Thanks for all the info guys. it's an auto 4x4, 150k on the truck, 25k on the trans.
2002 F-250 ccsb, 7.3, Auto, 4x4, BDP Tunes, Stealth Drop In, 4" MBRP, 6637, Van turbo WW ATS, Frantz Bypass,Drilled & Slotted Rotors
mbg75 is offline
