2 cycle oil - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 22 (permalink) Old 09-23-2007, 05:38 AM Thread Starter
All done now
Arisley's Avatar
2 cycle oil
Just for kicks, I threw a quart of 2 cycle oil in the fuel tank when I filled up the last time.
I was very sceptical.
Still not convinced.............
However; It seems like my injectors are quieter and happier. It seems like my motor is a little snappier. It seems like the tank is running out slower. It seems like my turbo is happier.
All of this may be placibo effect, but like I said before, I was sceptical.
I have about 500 miles on this tank now, just my initial feelings.
Arisley is offline
post #2 of 22 (permalink) Old 09-24-2007, 02:38 PM
utah get me two
Re: 2 cycle oil
andy did you read the lubricity thread in this forum,check it out it has 2 stroke as a fuel additive along with othere great read,also in the mpg forum there is a long thread about 2 stroke,but you gotts to use ashless 2 stroke.but you probably knew all this...........
[SIGPIC][/SIGPIC]2001 f250 4x4 cc sb 6 in lift...dp 6 pos..
glamis_dave is offline
post #3 of 22 (permalink) Old 09-24-2007, 03:58 PM Thread Starter
All done now
Arisley's Avatar
Re: 2 cycle oil
Yep, knew about the ashless stuff. Had to talk myself into it. But I figured with 238K on my injectors I could not hurt them. I will check out the other threads.
Thanks
Arisley is offline
post #4 of 22 (permalink) Old 09-24-2007, 04:41 PM
utah get me two
Re: 2 cycle oil
yea and i forgot to mention, the accepted ratio so far, is 1oz per gallon
post #5 of 22 (permalink) Old 09-24-2007, 07:13 PM Thread Starter
All done now
Arisley's Avatar
Re: 2 cycle oil
Yep. I threw a quart in 32 oz in 38 gallon tank. Close enough for me. I usually fill up pretty close to 32 gallons, so a quart it is.
Arisley is offline
post #6 of 22 (permalink) Old 09-24-2007, 10:28 PM
< pissed off pumkin.
skylinedan's Avatar
Talking Re: 2 cycle oil
I ran a quart last winter, and it did seem a litle quieter. Now with the Reg. return fuel system it might be interesting to see how much of a difference it makes. I got 18.4 MPG a couple weeks ago on a tank, so I don't know if I could Improove opone that.
Dan
2003 F-350 4x4, Ext cab. 7.3 AFE stage II 4" turbo back exhaust, garret GTP 38, 1.15 van turbine housing,EBPV deleated, non waste gated, ATS compresor housing, WW II, bellowed up pipes, CFM + spyder conversion, Hydra chip with Bill's tunes, CCV mod, Hutched, harpooned, RR fuel system, 6.0 trans cooler, Swamps IDM, HPX.
skylinedan is offline
post #7 of 22 (permalink) Old 09-25-2007, 05:00 AM
utah get me two
Re: 2 cycle oil
ive heard it said,that it takes a couple of tanks to see results,for some reason,been so broke i cant afford diesel,let alone 2 stroke oil.........
post #8 of 22 (permalink) Old 09-25-2007, 11:55 PM
SyN
Lubrication Addict!!
Re: 2 cycle oil
This morning before filling up, I poured in 16oz of Amsoil HP Injector 2-Stroke oil that I had left over. And to be quite honest after driving across town and back. Pulling into the driveway and sitting listening to the 7.3 idle it did seem a bit smoother and quieter. I just might have to add 16oz every other tank along with Opti-Lube every tank. I just might be doing something right for once.
2001 F250 XLT CC 4X4 AUTO SWB
{295K miles}.
Donaldson AIS Intake w/ZooDad
4" MBRP Turbo Back Exhaust.
DieselSite By-Pass Coolant Filter/{ELC}&RMI-25
DieselSite By-Pass Transmission Filter/Lg Magnet
Delete Mods-->{Foil & AIH}
203*{T-Stat}w/Billet Housing
SS HPX line-CCV{to atmosphere}
Marinco Heater Plug
Oil-->T6 5W-40 w/Amsoil Filter
SyN is offline
post #9 of 22 (permalink) Old 09-26-2007, 02:32 AM
<----Colin Banks
mattymx's Avatar
Re: 2 cycle oil
It has actually more than paid for itself for me so far in MPG gains.
mattymx is offline
post #10 of 22 (permalink) Old 09-26-2007, 03:09 AM Thread Starter
All done now
Arisley's Avatar
Re: 2 cycle oil
It did'nt take a couple of tanks for me, I could hear the difference in like 15 seconds, it was almost like flipping a switch. I don't care about the MPG, that is a bonus, I already can hang with any 1/2 with a V8 unloaded MPG wise, and if you put a load on it I will kill any gasser. I am going to drive a full size pickup anyways, so why not drive a real one.
Arisley is offline
