Leaking oil plug - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 23 (permalink) Old 09-26-2008, 10:15 PM Thread Starter
Back in a Powerstroke
ford fanatic's Avatar
Leaking oil plug
Anyone have any problems with their oil plugs leaking? Just did an oil change and replaced the copper washer and made sure the plug was tight, it helped out, but didn't completely stop the leak. It's an 02 PSD, any suggestions?
06 CCSB F350 Powerstroke 4x4
ford fanatic is offline
post #2 of 23 (permalink) Old 09-26-2008, 10:50 PM
OBS junkie
Cat_Rebel's Avatar
Re: Leaking oil plug
Did you get the little copper/plastic washer to go around it? I replaced the one on the 00 with a basic auto parts store one & didn't have another issue. Only problem is it has a slight pedistal & dipstick tube leak that will drip down & look like a plug leak.
97 F350 CCLB "Da Bus"
RIP Will Iott
"This ain't no practice run"
Cat_Rebel is offline
post #3 of 23 (permalink) Old 09-26-2008, 10:55 PM
PSN Mega Miler
crowz's Avatar
My 02 leaks too. Started doing it on this last oil change. I havent found a washer yet to replace the one that was on it when I got the truck. I need to remember to ask the parts houses around here if they have one.
Its more like having a constant drop of oil hanging on the drain plug all the time. Doesnt seem to really leak much or anything but Im watching the oil level to be safe till next oil change.
2002 F250 SuperDuty Lariat PSD 7.3 Crew Cab 4x4 302,000+ miles.
, Valvoline Extreme Blue 5w40 Synthetic,
, Clifford Matrix 50.5x Alarm
, P3 Brake Controller, Swamps Injectors, PHP Tunes
crowz is offline
post #4 of 23 (permalink) Old 09-26-2008, 11:25 PM Thread Starter
Yes I replaced the copper washer, the one that was on there looked as if it had been there forever. Everything above the bottom of the oil pan is dry, so I assumed it was the plug that was leaking. I will look further to see if it is the dipstick tube leaking also. Thanks.
post #5 of 23 (permalink) Old 09-26-2008, 11:30 PM Thread Starter
I got a replacement washer at Pep Boys. Mine also seems to be a constant drop hanging on to the drain plug. The truck will be sitting for a few days til the weather clears up so I can install my leveling kit, guess I'll see what size oil spot is under the truck then. Thanks.
post #6 of 23 (permalink) Old 09-27-2008, 12:54 AM
Starting Over
kainers's Avatar
grey rtv stuff is bad ass.You don't even have to get it half ass clean and it still stops the leak.Tacky sticky stuff.
20 bucks a tube and it takes less then a dime size.Put a little around the washer before you put the plug back in and tq it down no more leak.
kainers is offline
post #7 of 23 (permalink) Old 09-27-2008, 02:08 AM Thread Starter
I was thinking either that or maybe some sort of teflon tape. Your idea goes along the idea of a different style washer, I was thinking maybe rubber would make a better seal than copper. Thanks for the ideas.
post #8 of 23 (permalink) Old 09-27-2008, 02:25 AM
Starting Over
kainers's Avatar
I got one of those rubber oring washers from the AZ and it fell apart on the 2nd change.The inner sperated from the outer ring.I need to go to ford and just get oem it lasted allot longer
kainers is offline
post #9 of 23 (permalink) Old 09-27-2008, 03:27 AM
2nd class citizen
1snotrocket's Avatar
i use a honda drain plug washer/gasket. go to the honda dealer and ask for a drain plug gasket for 1996 honda civic. you will never use the copper junk again.
2003 CRW CAB LB 4X4 6SPD,AFE STAGE 2,38r,DP TUNER,4'' MBRP,FASS 15,Farmers Disel Performance 160/100 injectors,ITPREG.RETURN,TERMINATOR
2001 crw cab short bed auto 4x4 5"exhaust afe stg 2,f6,jw trans,terminator,cass. stg2's,itp reg return,fuel lab pump.
1snotrocket is offline
post #10 of 23 (permalink) Old 09-27-2008, 04:06 AM
bigd4me2's Avatar
Honda drain plugs are all the same size. they also use an aluminum washer, but i use the same method as kainiers, been doing it for 15 years. we do it on all racing motorcycles too, can't have any leaks on the track!
02 dmax cc dually 4wd "miss piggy" tow bitch, afe pr7, magnaflow, Kennedy lift pump, dual rail mount filters, PPE tunes
00 f350 srw rc=6100lbs
ats comp housing,bdp 1.0 exhaust,afe pr7,4in turbo back magnaflow,hx cross,di regulated return,bbha,dp hi,40,80e,120r,6.oh no cooler autometer gauges, dual rail mount filters
bigd4me2 is offline
