fuel filter questions - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 09-23-2008, 03:30 AM Thread Starter
nchappy's Avatar
1. anyone ever change a fuel filter and have it not be brown?
2. what is the secret to get the 7.3L filter cover sealed the first time? it would be nice to do it just once without squirting fuel all over the engine.
thanks,
neil
2001 F350 7.3L ZF6 XLT DP-Tunes
2006 F250 6.0L XL
2006 F350 6.0L KR
2008 VW Touareg 4.2L
nchappy is offline
post #2 of 11 (permalink) Old 09-23-2008, 03:35 AM
Re: fuel filter questions
Very rarely do I get much junk in my fuel filters. They are generally near the same color as new, other than some discoloration from the color dye in the fuel. If the filters are turning really dark/black chunks you are either running them too long or are getting dirty fuel.
Be careful that you get the orings facing the correct direction and lube them with some engine oil.
69W900A is offline
post #3 of 11 (permalink) Old 09-23-2008, 03:35 AM
treyloco's Avatar
Make sure you pre-lube all the o-ring w/ diesel before installing and make sure the v shaped ring is on in the proper direction.
'03 7.3 lariat crew cab dually FX4
AFE Stage 2
DI 6 position
warn premium hub locks
4" mbrp straight piped exhaust
custom built trans w/ triple disc converter
'07 Front End w/ 6000k HID
AIH delete & CCV Mod
Just over 100k miles
"Powerstroke Performance Headquarters!"
treyloco is offline
post #4 of 11 (permalink) Old 09-23-2008, 03:36 AM
treyloco's Avatar
well someone beat me to it
AFE Stage 2
DI 6 position
treyloco is offline
post #5 of 11 (permalink) Old 09-23-2008, 03:45 AM Thread Starter
nchappy's Avatar
run about 10K miles on my last 2 filters, no chuncks but filter media was brown. used more biodiesel this summer then ever before, maybe it cleaned out some crap.
i know about the gaskets sitting the correct way.
do you use oil or diesel to lube the gasket?
2006 F250 6.0L XL
2006 F350 6.0L KR
nchappy is offline
post #6 of 11 (permalink) Old 09-25-2008, 07:29 PM
Tampa450's Avatar
Bio-D has done that to my filters before.
I had a DI regulated return on my 550 and if the gauge showed a drop in fuel pressure I would change the filter. (usually I'd change it before it got to that point, tho)
I always use diesel on the gasket (I think that what the directions say?)
And I think Im gonna go ahead and splurge on that tool that DI sells for the fuel filter, so at least I can FEEL like a pro when I change the filter.
-Shawn Collister #16
-2002 F250 Crew/4x4/Auto- 4" Magnaflow, AIS, Vegistroke, ScanGauge, AC's tuned by Swamps
-2003 F450 Crew/4x4/Auto- 4" exhaust, Alcoas, Air ride, AIS, Garrett 38R, X-monitor
Tampa450 is offline
post #7 of 11 (permalink) Old 09-26-2008, 05:42 AM
I would get the Baldwin filter from DieselSite. Just need a 3/8 socket wrench to remove the filter.
Here's the description:
The Baldwin fuel filter replaces your OEM Powertroke filter and has a new cover attached to the filter. This makes filter changes easier, cleaner, and less prone to leaking. The OEM cap gets stressed over time from frequent changes. This filter solves this dilema.
Simply unscrew the OEM filter, remove element, and install new Baldwin fuel filter. Recommended change intervals on Powerstroke fuel filters is 10k miles.
snakyjake is offline
post #8 of 11 (permalink) Old 09-26-2008, 05:42 AM
You may also want to consider installing a Baldwin/Dahl filter.
post #9 of 11 (permalink) Old 09-26-2008, 11:54 AM
+1.
ITP Pre-Pump Kit
Roll You Own Version - works on a 7.3 too
Good luck.
Al
FTG-05 is offline
post #10 of 11 (permalink) Old 09-26-2008, 11:55 AM
PSN Mega Miler
crowz's Avatar
Mines always blue tinted. Course the 2 stroke oil I run probably effects it some
2002 F250 SuperDuty Lariat PSD 7.3 Crew Cab 4x4 302,000+ miles.
, Valvoline Extreme Blue 5w40 Synthetic,
, Clifford Matrix 50.5x Alarm
, P3 Brake Controller, Swamps Injectors, PHP Tunes
crowz is offline
