Sythetic Trans Fluid for Torqueshift - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 09-14-2008, 03:12 PM Thread Starter
More Power Tim
Who makes a synthetic replacement for the mercon sp that goes into the torqueshift. I know of Redline, and Amsoil. Anybody else?
2006 F-350 PSD FX4 CC LB SRW 4X4
fandini is offline
post #2 of 6 (permalink) Old 09-15-2008, 07:28 AM
PSN Mega Miler
crowz's Avatar
Re: Sythetic Trans Fluid for Torqueshift
I know that companies like amsoil and others have added the mercon sp the list but I find it odd to say the least that ford comes out with a special fluid just for that trans and amsoil and others suddenly add it the label of a trans fluid they were already making.
GM DEXRON II, III & VI
• Ford MERCON, MERCON V & SP
• Chrysler ATF+ through ATF+4®
• Honda Z-1 (Not for use in CVT transmissions)
• Toyota Type T and T-IV
• Mitsubishi/Hyundai Diamond SP II & III
• Allison C-3, C-4, Caterpillar TO-2
• Voith G607, G1363
• ZF TE-ML 14A, B & C
• MB 236.1, 236.2, 236.6, 236.7, 236.9
• BMW 7045E, JWS 3309, NAG 1 & 2
• LT 71141 (ESSO), Nissan Matic D, J & K
• Vickers I-286S & M-2950S
Excellent for power steering units that use ATF.
Not for use in CVT transmissions.
Sorry adding something to a label doesnt "upgrade" a fluid.
Id stick with mercon sp stuff if it was me.
The mercon sp is fully synthetic already so why switch and run the risk?
2002 F250 SuperDuty Lariat PSD 7.3 Crew Cab 4x4 302,000+ miles.
, Valvoline Extreme Blue 5w40 Synthetic,
, Clifford Matrix 50.5x Alarm
, P3 Brake Controller, Swamps Injectors, PHP Tunes
crowz is offline
post #3 of 6 (permalink) Old 11-06-2008, 06:01 AM
I don't see why you would want to go with another oil for the Torqshift? The Mercon SP has turned out to be a great synthetic oil and can be bought for pretty cheap online. I've been impressed with the oil analysis I've seen on other sites and by how clean my oil is everytime I drain it every 15k miles.
dc3655 is offline
post #4 of 6 (permalink) Old 11-06-2008, 10:17 PM Thread Starter
More Power Tim
I see your point.
Maybe those other guys are able to add the mercon sp to the list because they are already full synthetics, but I do find it kind of fishy.
I don't guess you would gain anything going from one synthetic to another anyhow.
fandini is offline
post #5 of 6 (permalink) Old 11-07-2008, 12:39 AM Thread Starter
More Power Tim
You drain your every 15,000? I thought the manual called for every 30,000.
Do you do it yourself, or do you take it to the dealer or someone who does a complete fluid exchange?
fandini is offline
post #6 of 6 (permalink) Old 11-08-2008, 12:44 AM
matthewd11's Avatar
Synthetic flushes arent that expensive. AFAIK they are around 120$ for about 12 qts. So maybe 2 flushes should get everything.
matthewd11 is offline
