cooling-coolant - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 16 (permalink) Old 09-14-2007, 01:32 AM Thread Starter
utah get me two
cooling-coolant
hey now.got a friend building a mustang stroker motor,cant rember hoe we got on the cooling subject,but we are divided on thermstats and cooling...i maintain that without a thermstat,and running it hard you will over heat,reason being is that the coolant doesent have sufficent time to be in the radiator to cool down,he thinks more air means more cooling,anybody care to chime in with a link that would prove one of us right.....along with this most people will argue with me when i say you can die from hypothermia in 90 degree water,but it's still true...
[SIGPIC][/SIGPIC]2001 f250 4x4 cc sb 6 in lift...dp 6 pos..
glamis_dave is offline
post #2 of 16 (permalink) Old 09-14-2007, 03:02 AM
Caption This
444-4D's Avatar
Re: cooling-coolant
You are wrong.
If only those who knew what they were talking about replied, this thread would still be on page one.
2000 F-250 CC 4x4 PSD Auto
444-4D is offline
post #3 of 16 (permalink) Old 09-14-2007, 03:09 AM
Some Kinda Diesel Oracle
thehammer69's Avatar
Re: cooling-coolant
Originally Posted by 444-4D View Post
You are wrong.
Hammer
2002 Corvette Z06...my Auto-X, track car, and play toy
2001 Ford F250 Lariat 7.3PSD...daily driver
2000 BMW 328i...another daily driver for the GF
1997 Yamaha YZF1000R
1995 Volvo WIA-64TTES w/ Cummins N14-500hp/1750 ft/lbs
1994 Chevy Camaro Z28...will be selling soon
thehammer69 is offline
post #4 of 16 (permalink) Old 09-14-2007, 03:19 AM
Corona Killa
THEDIESELMAN's Avatar
Re: cooling-coolant
I have ran a SBC without a t-stat and it never even got hot so I would have to say it will stay cooler without a t-stat.
2007 DODGE 2500 CREW CAB 4X4 5.9 LITER CUMMINS
2002 FORD F-250 CREW CAB 4X4 POWERSTROKE
THEDIESELMAN is offline
post #5 of 16 (permalink) Old 09-14-2007, 05:59 AM
Re: cooling-coolant
if u run a vehicle without a tstat in winter, it will never get warm enough to warm the vehicle up. thats pretty much it.
Diezel Dawg is offline
post #6 of 16 (permalink) Old 09-14-2007, 06:58 AM Thread Starter
utah get me two
Re: cooling-coolant
my real world experence says something different,both times thermstat failed in road,2 different vehicles,both times ran it mild 55-75 mph no problems,both times thought well no problems lets run it like i like to..80-90mph 3 min later overheating,,slow down and it cooled off....hhhmmmmm
post #7 of 16 (permalink) Old 09-14-2007, 05:19 PM
Corona Killa
Re: cooling-coolant
When a t-stat fails it usually stays closed so it heats everything up.
post #8 of 16 (permalink) Old 09-15-2007, 03:50 AM
Re: cooling-coolant
I've run most of my engines with no T-stat, but you need something to control coolant flow. Especially if it's a race engine that will see high RPM and high coolant flow situations. I just used washers that have the correct OD to fit in the housing and then changed the ID until I get the desired flow.
If the engine is used in a driver the only thing you will notice is the coolant will take a bit longer to warm up, but after that the temps will be much more constant. You should have some device to control coolant flow, whether static or dynamic, in the system.
69W900A is offline
post #9 of 16 (permalink) Old 09-15-2007, 07:57 AM Thread Starter
utah get me two
Re: cooling-coolant
are you guys really thinking ???? with no thermastat..running it hard,hard it will overheat.....
post #10 of 16 (permalink) Old 09-15-2007, 01:22 PM
Caption This
444-4D's Avatar
Re: cooling-coolant
A lot of things will cause an engine to overheat. Coolant flowing too fast thru the radiator isn't one of them. Wasn't that the original question?
444-4D is offline
