How often do you - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 09-01-2008, 03:43 PM Thread Starter
Turbo boost
CoolantVc8's Avatar
How often do you
How often do you change you auto transmission fluids.
CoolantVc8 is offline
post #2 of 11 (permalink) Old 09-01-2008, 09:54 PM
Tampa450's Avatar
Re: How often do you
I get it flushed once a yr on both my trucks - to change 100% of the fluid.
-Shawn Collister #16
-2002 F250 Crew/4x4/Auto- 4" Magnaflow, AIS, Vegistroke, ScanGauge, AC's tuned by Swamps
-2003 F450 Crew/4x4/Auto- 4" exhaust, Alcoas, Air ride, AIS, Garrett 38R, X-monitor
Tampa450 is offline
post #3 of 11 (permalink) Old 09-02-2008, 12:32 AM Thread Starter
Turbo boost
CoolantVc8's Avatar
Where do you have this service done is it expensive
post #4 of 11 (permalink) Old 09-02-2008, 01:14 AM
Tampa450's Avatar
The most expensive part is buying all the fluid. I believe Mobil1 was $6 a qt last time I did it. You have to buy 15 qts so thats about $100 on the fluid.
Im pretty sure they charge me $50 for the flush.
So its about $150
I get it done at a place called "TuffY"
Its a jiffy-lube style quick oil change joint.
The machine they use hooks up to existing tranny fluid lines and uses the idling of the truck to pump the old fluid into the machine and replace it with new.
There are other tranny flush machines that work different and might not be such a good idea.
Tampa450 is offline
post #5 of 11 (permalink) Old 09-02-2008, 02:30 AM
Mine is done every 20,000 miles. Which translates into once a year. And it is done at the shop that rebuilt it.
Total cost is $125 for dino oil, or $200 for syntetic.
1997 F350 7.3L OBS (Old Big and Slow)
3" Downpipe (cat delete 364.5 days a year)
Custom tunes by ME
AFE Intake
Rebuilt Transmission(The works-Tripple disk TQ, All Steel insides)
Old Big and Slow is offline
post #6 of 11 (permalink) Old 10-01-2008, 12:37 PM
Know nothin' PSD driver
Greg373's Avatar
When I got my BTS, Brian said that the Mobil 1 I put in should be good for 50,000 miles.
[SIGPIC] 2001 F-350 CC SRW 4X4 Lariat;
PMR's
[/CENTER][/SIGPIC]
Greg373 is offline
post #7 of 11 (permalink) Old 10-01-2008, 12:51 PM
fbilly420's Avatar
I flush mine once a year. It cost me $100 for synthetic and I do it my self with the flush proceedure that Mark wrote up.(sticky thread) Very helpful and worked great for me.
2001 F250, CCSB, 4X4, Auto, Forged rods
Lots of go fast parts and still slow.
2001 F250, STD cab, 2WD
Frame is a little shorter now
workin on body
engine build underway
fbilly420 is offline
post #8 of 11 (permalink) Old 10-02-2008, 12:22 AM
Starting Over
kainers's Avatar
15k fluid
30k fluid filter
BTS trans dino oil
kainers is offline
post #9 of 11 (permalink) Old 10-04-2008, 02:53 AM
SyN
Lubrication Addict!!
Once a yr... Just before winter. I just drain the pan via the plug. Change my spin on filter. And add 2 gals of Amsoil TD.
2001 F250 XLT CC 4X4 AUTO SWB
{295K miles}.
Donaldson AIS Intake w/ZooDad
4" MBRP Turbo Back Exhaust.
DieselSite By-Pass Coolant Filter/{ELC}&RMI-25
DieselSite By-Pass Transmission Filter/Lg Magnet
Delete Mods-->{Foil & AIH}
203*{T-Stat}w/Billet Housing
SS HPX line-CCV{to atmosphere}
Marinco Heater Plug
Oil-->T6 5W-40 w/Amsoil Filter
SyN is offline
post #10 of 11 (permalink) Old 10-04-2008, 02:58 AM
King Dingaling
TANK'S 250's Avatar
Mine is a manual tranny,...and I beat on mine pretty hard...so I change it every 20-25k
Most automatic transmissions fail due to a breakdown of the transmission fluid (oil) caused by overheating. This chart provides a graphic display of heat's contribution to transmission failure.
The effect is also cumulative. Short term exposure to high heat levels (or even prolonged exposure to moderate heat) can break down the oil to the point where even very short episodes of overheating will lead to failure.
TANK'S 250 is offline
