Opinions on wix filters. - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 16 (permalink) Old 01-20-2013, 11:24 PM Thread Starter
I've put them in company trucks at work, what are your opinions on them for a personal vehicle
05 F-250 xlt crew cab 6.0 4" back to 6" black mitres,blue spring mod,Airaid intake, 6k hid's,sinister coolant filter,egr delete, intake elbow leveling kit, SCT Tuner, recon mirrors lights cab lights and 3rd brake light, big rig ice,billet grill
Bustedknuckles7892 is offline
post #2 of 16 (permalink) Old 01-20-2013, 11:41 PM
40 lug nuts
Snake's Avatar
Re: Opinions on wix filters.
WIX makes good filters. Just make sure it's cross referenced properly.
BULLETPROOF DIESEL
Biofuels Technologies
1A Auto
2005 F-250
Snake is offline
post #3 of 16 (permalink) Old 01-20-2013, 11:56 PM
My boss gave me a copy of a filter test the army did awhile back between CAT, Baldwin, Donaldson, fleet guard, wix, and lube-finer. WIX was once of the worst filters actually. Top 3 were CAT, Baldwin, and fleet guard.
Sent from my iPhone using AutoGuide.com App
drmisherre is offline
post #4 of 16 (permalink) Old 01-21-2013, 12:21 AM
Sold NAPA filters for 15 years. IMHO they are engineered poorly. There is a ton more surface area than most competitors. One of their claims of greatness is more pleats and thicker paper with tighter holes to catch more dirt. This actually drives up oil pressure in almost all cases. This was not a bad thing if you were running a carberated hot rod gas burner. For newer vehicles with more stringent specs, filters should match OEM specs for many reasons and WIX does not seam to get that. A perfect example is them opting to leave off cellophane wrap on 6.0 PSD fuel filters and allowing moisture to the fuel injectors burning up millions of injectors. For whatever reason, they are not on top of current technology.
I have seen many vehicles see a 5 psi increase in oil pressure switching to a WIX filter. This means to me it has too much restriction. I think their air filters do the same thing. They are great at collecting dirt, but create too much restriction and can decrease power.
WHPSExcursiom is offline
post #5 of 16 (permalink) Old 01-22-2013, 02:29 AM
WIX XE Oil Filters
The WIX XE (extra-efficiency) oil filters are the most efficient and cost-effective filters in severe conditions. They feature microfiber "glass" media in order to filter out more of the small, engine-destroying particles. This special glass media offers less resistance to oil flow, therefore providing better protection on start-ups, especially in cold weather. Also, the glass media won’t absorb water like cellulose media.
Regular OEM Factory recommended filters are a minimum requierment for filtration.
Why would a Filter company make an XE type filter in the first place?
If the OEM pick was the best like your mechanic says or anyone else for that matter, then why does every filter manufacture offer synthetic media extra performance filters?
Cause people are just bad at math....
Javier
sootieoil is offline
post #6 of 16 (permalink) Old 01-23-2013, 01:40 AM Thread Starter
Thanks for the replies, the injector comment I believe is true. I ran only wix fuel filters on my 6.0 service truck for a little over a year and it finally laid down on me with 4 fouled injectors. The main reason I ran them is that we have a fleet program with a local auto parts store on the filters, so we get them at a considerable discount. And the closest dealer is a little over an hour away.
post #7 of 16 (permalink) Old 01-23-2013, 01:14 PM
Moderator
PsRumors's Avatar
I run a Napa gold filter, which is Wix, and never had an issue. The oil analysis loom very good as well even after 6000 miles of usage.
'97 SCLB 4x4, 3.55, D60 w/ TrueTrac, 6637, Banks Techni-cooler, BTS Trans, Tru-Cool 4921 Trans Cooler, 1.0 exhaust housing, no ebv, 3" DP, Straight Exhaust, E-Fuel, TW tunes, International WP, 203*, Isspro Gauges
PsRumors is offline
post #8 of 16 (permalink) Old 01-23-2013, 01:17 PM
Administrator
Zmann's Avatar
I can get wix for free and it would come with a free oil change
i pay for my own Motorcraft/Racor filter and non bulk oil out of pocket
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #9 of 16 (permalink) Old 01-23-2013, 01:21 PM
Caption This
444-4D's Avatar
You are wasting your money.
If only those who knew what they were talking about replied, this thread would still be on page one.
2000 F-250 CC 4x4 PSD Auto
444-4D is offline
post #10 of 16 (permalink) Old 01-23-2013, 01:27 PM
Administrator
Zmann's Avatar
I don't think so
I have seen images of the aftermarket caps failing and filters falling apart
as far as the oil I don't trust those guys to not mix up oil and not now what oil to use in a diesel
this is a known issue for the 6.0 and the OP has the 6.0 as far as a 7.3 it may not apply
DTR's Donation page
RIP DTR Ron
Zmann is offline
