75-140 Gear Oil - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 14 (permalink) Old 08-27-2008, 07:31 PM Thread Starter
6.4's are my Hero.
Reubine's Avatar
Send a message via AIM to Reubine
75-140 Gear Oil
Were is the best place to get some gear oil for my truck?? Thanks
Reuben
'95 Ford F-350, CC,4x4,SWAMPS 300/200Hybrids,H-11 Head studs,Comp 910 Springs,Chromemoly push rods,modded TE 17*, GARRETT GT40 TURBO,built trans with 3 disc billet convertor,SWAMPS 6 position chip,3"DP to 6" single, IDM Mod,Gauges,'02 SD IC,Electric Fuel system and bunch of other stuff.
Reubine is offline
post #2 of 14 (permalink) Old 09-02-2008, 04:12 AM
Re: 75-140 Gear Oil
A store would be your best bet I think.
That being said, how much do you want to spend? The BEST off the shelf gear is RedLine synthetic. If you don't want to spend that much Valvoline syn, Delo ESI and Mobil are all good oils that cost less. Delo ESI is the only non-syn oil that I would trust.
69W900A is offline
post #3 of 14 (permalink) Old 09-02-2008, 05:21 AM
Cummins Power
mech2161's Avatar
Re: 75-140 Gear Oil
I've been using Valvoline. It readily available at most parts stores.
Kevin
12v CONVERSION IN PROGRESS, Special thanks to:
South Bend Clutch, MOTORSPORTSSUPPLY.COM, Pure Diesel Power & Performance, Carson Stauffer Diesel Service, Weston Shupe, zstroken
mech2161 is offline
post #4 of 14 (permalink) Old 09-02-2008, 12:12 PM
Needs more hours per day
jtharvey's Avatar
Re: 75-140 Gear Oil
You can always get a full synthetic Motorcraft version of it from Ford too. I don't know much about it though.
Jeremy
2000 F-350, CCLB, SRW, 4x4, '04 5.9 Common Rail Cummins Conversion
F1 sticks, Evil Twins Dual CP3's, F1 Springs, Helix 2 Cam, ARP headstuds, ED Turbo, Smarty, BTS Trans
Eventually: Compound Turbos
jtharvey is offline
post #5 of 14 (permalink) Old 09-03-2008, 12:35 AM Thread Starter
6.4's are my Hero.
Reubine's Avatar
Re: 75-140 Gear Oil
Thanks guys I ended up going with a 85-140 that I got from Carquest. Can't remember what kind it was but it was cheap so I got it.
Reubine is offline
post #6 of 14 (permalink) Old 09-03-2008, 03:47 AM
Re: 75-140 Gear Oil
If it wasn't synthetic I wouldn't use it in the rear diff. Cheap is NOT good.
69W900A is offline
post #7 of 14 (permalink) Old 09-03-2008, 02:06 PM Thread Starter
6.4's are my Hero.
Reubine's Avatar
Re: 75-140 Gear Oil
I'm not sure if It was synthetic or not, I don't remember. All I know is the synthetic I had in it before leaked so I had to put a new gasket(bead of silicone) on the cover.
Reubine is offline
post #8 of 14 (permalink) Old 09-03-2008, 07:08 PM
Subject Matter Expert
PowerstrokeJunkie's Avatar
Re: 75-140 Gear Oil
What does the forum think of Royal purple, how about Amsoil? I am approaching 500 miles since i installed my gears, i put cheap mobil stuff in there to get me by, now i want to put good stuff in, should i look for red-line?
Stock
PowerstrokeJunkie is offline
post #9 of 14 (permalink) Old 09-04-2008, 06:11 PM Thread Starter
6.4's are my Hero.
Reubine's Avatar
Re: 75-140 Gear Oil
I had Amsoil in there before but I couldn't afford to spend 50 plus bucks for gear oil again.
Reubine is offline
post #10 of 14 (permalink) Old 09-05-2008, 05:20 PM
Sofa King Cool
BMac's Avatar
Send a message via AIM to BMac Send a message via MSN to BMac Send a message via Skype™ to BMac
Re: 75-140 Gear Oil
I'm using Royal Purple, no complaints about it yet
People Fly Airplanes, Pilot's Fly Helicopters
2002 F350 Extended Cab Shortbed
1977 Early Bronco
BMac is offline
