Lubricity Additive Study Results - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 14 (permalink) Old 09-08-2007, 07:54 AM Thread Starter
I thought this was the best place to put this.
Very interesting read from the Dmax guys.
http://dieselplace.com/forum/showthread.php?t=177728
I would liked to have seen them test 2 stroke in a higher concentration, such as the 1oz/gallon that I use, but very good info nonetheless.
gregrob is offline
post #2 of 14 (permalink) Old 09-08-2007, 03:54 PM
<----Colin Banks
mattymx's Avatar
Re: Lubricity Additive Study Results
I read that at TDG. Too bad they did not use the ratio we use for the 2 stroke oil. They went to 200:1 and we use about double that amount. Just shows that the oil works but might even work better with more oil used.
mattymx is offline
post #3 of 14 (permalink) Old 09-08-2007, 05:03 PM
< pissed off pumkin.
skylinedan's Avatar
Talking Re: Lubricity Additive Study Results
I agree on the used oil idea, I know a few guys driving big trucks and they put used oil in everty time they fill up. Just don't ever use trans fluid, I heard a story the other day. guy put it in his and got stoped for something, dot guy diped his tank and said he was running off road diesel because the stuff was red. I don't know if he got fined, butthat would be fun to explain. Just think of it as oil recycling and preventive maintence all in one package.
Dan
2003 F-350 4x4, Ext cab. 7.3 AFE stage II 4" turbo back exhaust, garret GTP 38, 1.15 van turbine housing,EBPV deleated, non waste gated, ATS compresor housing, WW II, bellowed up pipes, CFM + spyder conversion, Hydra chip with Bill's tunes, CCV mod, Hutched, harpooned, RR fuel system, 6.0 trans cooler, Swamps IDM, HPX.
skylinedan is offline
post #4 of 14 (permalink) Old 09-09-2007, 12:59 AM
<----Colin Banks
mattymx's Avatar
I will never add anything to my fuel that was not meant to combust. Also I would never run used oil with any truck that is HEUI or common rail. I dont want metal shavings getting by the filter and into my injectors.
mattymx is offline
post #5 of 14 (permalink) Old 09-09-2007, 01:03 AM
Corona Killa
THEDIESELMAN's Avatar
Yep used oil will never be put into my fuel.
2007 DODGE 2500 CREW CAB 4X4 5.9 LITER CUMMINS
2002 FORD F-250 CREW CAB 4X4 POWERSTROKE
THEDIESELMAN is offline
post #6 of 14 (permalink) Old 09-09-2007, 01:13 AM
MPG Moderator
Dave Whitmer's Avatar
Used lube oil combusts just fine in diesels. I've seen it used in up to 15% lube oil concentrations.
I would recommend filtering it some, though.
2000 F-350 SC 4x2 6 speed
Slammed 4"
Rugged Air Dam
315,000 miles
Dave Whitmer is offline
post #7 of 14 (permalink) Old 09-09-2007, 01:54 AM
Grumpy Old Bitter Bastard
389SixPack's Avatar
Good read. Where can I buy 100&#37; biodiesel? Guess I need to start making my own!!
aka - Grumpy .. aka - Bubba Grump .. aka - Bubba .. aka - Grumpy Old F... . . A "slow" fatass 9K Dually.
389SixPack is offline
post #8 of 14 (permalink) Old 09-09-2007, 01:59 AM
Corona Killa
Yes it will combust just fine but even if you filter it you will still have the trapped soot and other stuff just waiting to be released.
post #9 of 14 (permalink) Old 09-09-2007, 09:57 PM
MPG Moderator
Soot is not the problem. Soot is graphite and has lubricating properties even as a solid.
I would recommend at least 5 micron filtration to keep metallic particles from damaging injectors. 3 micron or 1 micron would be better.
Slammed 4"
Rugged Air Dam
315,000 miles
post #10 of 14 (permalink) Old 09-09-2007, 10:33 PM
Corona Killa
If soot was not a problem then why does the oil we use keep it from becoming a solid chunk I just wouldn't put anything in my fuel system and most of all the injectors that didn't need to be there .
