Rotella 5w40 good for 110 degree heat? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 05-22-2012, 06:31 AM Thread Starter
Im currently running Rotella 15w40 in my 7.3 and planning to switch to Rotella 5w40 when it comes winter time to help with cold starts since we see some single digit temps and if I am in the deer woods I cant plug it in (no power).
The truck does everything from hauling hay and daily driving to off-roading and some of that is done in temperatures around and sometimes over 110 degrees in the summer. Do yall think that the Rotella 5w40 will be fine at those high outside air temps and towing heavy?
I figure it would be since it is a 40 at temperature but I would still like to hear it from someone else.
Thanks
blkbird305 is offline
post #2 of 7 (permalink) Old 05-22-2012, 12:02 PM
FSJPat's Avatar
Re: Rotella 5w40 good for 110 degree heat?
Yeah, the 40 means it behaves like a 40 weight oil at high temps, so you should be fine. Also, since it is a synthetic oil, it resists heat breakdown and shear better than a conventional 15W40 oil.
2000 F250 7.3/ZF-6 SC/SB 2WD PHP tunes, MBRP 4" exhaust, 6637 intake, Hutch Mod, Frx, Hpx
FSJPat is offline
post #3 of 7 (permalink) Old 05-23-2012, 01:37 AM Thread Starter
I figured it would be fine but just wanted to make sure. Thanks
post #4 of 7 (permalink) Old 05-23-2012, 01:03 PM
Exploding the magma
rufushusky's Avatar
As you noted it is a 40wt oil at operating temp so nothing to worry about IMHO.
2002 F-350 ECLB SRW 7.3 4R100
6637 203* t-stat 08 diff cover Stancor HPX 6.0 trans cooler, Zone offroad leveling kit, Western UM 8'6" plow
Sold: 2004.5 Ram 2500 w/ 5.9 CTD, Reg Cab 48re
rufushusky is offline
post #5 of 7 (permalink) Old 05-24-2012, 12:28 PM
Administrator
Zmann's Avatar
I use it and see over 110
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #6 of 7 (permalink) Old 05-31-2012, 04:56 AM Thread Starter
Awesome! Thank yall.
post #7 of 7 (permalink) Old 06-24-2012, 05:25 AM
Need a ride.
Strokerstooge's Avatar
Another "you'll be fine" using synthetic 5-40 Rotella, use it year round here. I extend my oil changes to 8000 miles but doing so a lab test of your oil would be a smart thing.
03 F-250 7.3 XLT CC SB Auto 38R, S-B Intake, 4 inch MBRP Duals, Regulated Return, J Wood VB, DP Tuner, Isspros 3 Pillar, Terminator Scan Gauge, DS Coolant Filter, HPX
Strokerstooge is offline
