t6? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 05-08-2012, 01:39 AM Thread Starter
TURBO LIT 'N' THAT WAS IT
powerstrokin7.3's Avatar
t6?
i am currently running rotella 15w40, and i am thinking i am goin to switch to t6 5w40 for the next change and possibly the rev-x additive or the AR9100, if i switch will i be safe to keep my 5k oci, and will it be ok to use this oil year round, i live in central pa (cold winters, hot summers) and the truck sits outside. I use the truck for a little bit of everything, towing, highway driving, off road running, but i like to take care of it, thanx
03 SCSB (TOTALED)
00 ccsb zf6, 4" exhaust, 6637, ts chip w/php tunes, tinted glowshift gauges, ats ported housing,RR, leveled, ccv mod, pp mod, zoodad, intake heater delete, ebpv delete, WW2, t-500, South Bend clutch, more to possibly come
powerstrokin7.3 is offline
post #2 of 3 (permalink) Old 05-10-2012, 01:49 AM
Exploding the magma
rufushusky's Avatar
Re: t6?
Yeah, why not...it is still a 40wt oil at operating temp per SAEJ300. If you do UOAs you should have no problem running longer OCIs.
2002 F-350 ECLB SRW 7.3 4R100
6637 203* t-stat 08 diff cover Stancor HPX 6.0 trans cooler, Zone offroad leveling kit, Western UM 8'6" plow
Sold: 2004.5 Ram 2500 w/ 5.9 CTD, Reg Cab 48re
rufushusky is offline
post #3 of 3 (permalink) Old 05-10-2012, 02:06 AM Thread Starter
Re: t6?
i thought it would be fine, i jus wanted to hear it from someone else, and even if i did a uoa i would still probably change my oil every 5k, i jus like the piece of mind knowing i have good good/clean oil in the engine, and i usually only put about 5k on my truck in a year so its a once a year oil change usually, thanks
03 SCSB (TOTALED)
