Kendall 15-40 HDDO - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 06-17-2008, 03:50 PM Thread Starter
Kendall 15-40 HDDO
I can get this stuff from work pretty cheap. Anyone ever use it?
I know Kendall makes PRICEY synthetic racing oil... Never heard much about their diesel lineup.
gregrob is offline
post #2 of 5 (permalink) Old 06-17-2008, 03:55 PM Thread Starter
Re: Kendall 15-40 HDDO
Kendall Super-D® 3
PERFORMANCE YOU CAN COUNT ON
If you’re not using Kendall Super-D® 3 engine oil, you should be. Developed especially for EGR engines but also optimal for non-EGR engines, this world-class engine oil is ready for anything—from long hauls in the heat to off-road work in the cold. Super-D® 3 engine oil exceeds the current API CI-4 standards and has been approved by leading engine manufacturers around the world, including: Mack, Cummins, Mercedes Benz and Volvo. Which means whoever you are and whatever you’re doing, Super-D® 3 will deliver superior protection to your engines. Super-D® 3 engine oil also includes the following enhancements derived from the use of Group II base oils and proprietary additives:
Superior anti-corrosion protection
Excellent oxidation resistance
Reduced ring and liner wear
Improved oil consumption control
Outstanding soot control
gregrob is offline
post #3 of 5 (permalink) Old 06-17-2008, 04:27 PM
bigd4me2's Avatar
yes, back in the late 80's i worked for a guy that was anal about his trucks, and that is all he would use, kendall dino. i'm not saying it is the best, but this guy would not have used it if he thought there was something better.
p.s. greg its good to see you back posting, you have some catching up to do if you want to dethrone CAT!
02 dmax cc dually 4wd "miss piggy" tow bitch, afe pr7, magnaflow, Kennedy lift pump, dual rail mount filters, PPE tunes
00 f350 srw rc=6100lbs
ats comp housing,bdp 1.0 exhaust,afe pr7,4in turbo back magnaflow,hx cross,di regulated return,bbha,dp hi,40,80e,120r,6.oh no cooler autometer gauges, dual rail mount filters
bigd4me2 is offline
post #4 of 5 (permalink) Old 06-19-2008, 07:22 AM Thread Starter
Thanks, awesome av lol
gregrob is offline
post #5 of 5 (permalink) Old 06-27-2008, 04:38 PM
The Kendall oil produced today is not the same stuff produced in the '80's. The Kendall name was sold years ago, 1997 according to the Brad Penn website. The original "recipe" (so to speak) oil is still being produced by Brad Penn Refinery, former owners of the Kendall name, and they also produce diesel oil. Look under "Additional Products" at http://www.bradpennracing.com
A buddy of mine builds racing engines and he swears by this stuff. He uses the diesel oil in his truck also. IIRC he said it was around $70 for a 4 gallon case, however, that was awhile back.
'97
F250 HD, Crewcab, Shortbed, 4x4, Auto, Pioneer Head Unit & speakers, Tymar intake, Tymar HPX, shimmed FPR, 3 inch downpipe & straightpiped, DP-Tuner with a couple tunes (For now)!
My Mechanical Philosophy: If it don't fit.....FORCE IT, if it breaks it was weak and needed to be replaced anyway
Racecarhauler is offline
