diesel fuel with gas in it - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 10-14-2011, 08:54 PM Thread Starter
hendricksbus's Avatar
i got some fuel from a girl friend of the mother inlaws, she claims she was at a 1/8th of tank before accidentaly filled up with diesel. the fuel smells like gas, would i be safe to run five gallons of it a time with a 3/4 of full tank? or should i just burn it in my heating stove?
1996 F-250,Ext.cab,LB,4x4
stock tires
180K,6 pos chip,Open air filter, 3'' down pipe,fpr mod,ccv mod
4.10s gears!
Boost, Pryo and transmission gauges
sonnax shift improver kit
bronco tank mod
hayden cooler for transmission
hendricksbus is offline
post #2 of 11 (permalink) Old 10-14-2011, 08:57 PM Thread Starter
Re: diesel fuel with gas in it
it was an 04 dodge dakota!
stock tires
4.10s gears!
bronco tank mod
post #3 of 11 (permalink) Old 10-14-2011, 09:07 PM
Moderator
PsRumors's Avatar
Burn it....gas can do bad things to a diesel
'97 SCLB 4x4, 3.55, D60 w/ TrueTrac, 6637, Banks Techni-cooler, BTS Trans, Tru-Cool 4921 Trans Cooler, 1.0 exhaust housing, no ebv, 3" DP, Straight Exhaust, E-Fuel, TW tunes, International WP, 203*, Isspro Gauges
PsRumors is offline
post #4 of 11 (permalink) Old 10-14-2011, 09:19 PM
mxredneck's Avatar
Unless you are a blender
1996 F-350 CCLB dually, 4.10, 235/85R-16, ZF5, Tymar intake, Alabama Flowmaster, Isspro gauges, TS chip, Tightwad Mod
mxredneck is offline
post #5 of 11 (permalink) Old 10-14-2011, 09:27 PM
Moderator
PsRumors's Avatar
But would you trust "there is ABOUT an 1/8th of a tank"?
PsRumors is offline
post #6 of 11 (permalink) Old 10-15-2011, 01:09 AM Thread Starter
will the gas seperate from the diesel if left set for awhile? and no i dont trust that 1/8th of tank story. got it for free. i may just find a use for other than in my truck. thanks for the replies.
stock tires
4.10s gears!
bronco tank mod
post #7 of 11 (permalink) Old 10-15-2011, 01:11 AM
I wouldn't take the chance. This gamble can lead to more money in repairs than saved on one tank. Make some molotov cocktails with it. Always a good time.
2003 7.3 CCSB
PHP Chip, Full Force Stage 2's, 38R, Tymar, ISSPRO EV2 Boost/Pyro/Tranny, Diamond Eye Duals 4"
Skew12 is offline
post #8 of 11 (permalink) Old 10-15-2011, 01:43 AM
Mike's Diesel Performance
sick97psd1's Avatar
Send a message via AIM to sick97psd1
dont do it, the gasoline has no lubricating properties and whatever diesel there is left wont matter.
734-385-4208
sick97psd1 is offline
post #9 of 11 (permalink) Old 10-16-2011, 01:23 AM Thread Starter
i'm going too try too burn it in my jd 260, which is on its last leg so too speak. i'm going to thin it out with more gasoline and see how it run in the jd.
stock tires
4.10s gears!
bronco tank mod
post #10 of 11 (permalink) Old 10-16-2011, 01:24 AM Thread Starter
i'm going too try too burn it in my jd 260, which is on its last leg so too speak. i'm going to thin it out with more gasoline and see how it runs.
stock tires
4.10s gears!
bronco tank mod
