Diff Oil Question - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 16 (permalink) Old 06-11-2008, 07:49 PM Thread Starter
Soon to be a 6.4
lildevil02's Avatar
Send a message via AIM to lildevil02
Diff Oil Question
What are ya'll running in the diffs. I had a small leak in the rear I plan to address soon. I havenít changed the oil since back in 2002. I was leaning toward Royal Purple. Just seeing what others are running.
lildevil02 is offline
post #2 of 16 (permalink) Old 06-12-2008, 04:14 AM
2nd class citizen
1snotrocket's Avatar
Re: Diff Oil Question
i run good old chevron 80w/90 limited slip with the ford friction modifier.
2003 CRW CAB LB 4X4 6SPD,AFE STAGE 2,38r,DP TUNER,4'' MBRP,FASS 15,Farmers Disel Performance 160/100 injectors,ITPREG.RETURN,TERMINATOR
2001 crw cab short bed auto 4x4 5"exhaust afe stg 2,f6,jw trans,terminator,cass. stg2's,itp reg return,fuel lab pump.
1snotrocket is offline
post #3 of 16 (permalink) Old 06-12-2008, 04:43 AM
bigd4me2's Avatar
royal purple, no additive needed. its what most everyone is using.
02 dmax cc dually 4wd "miss piggy" tow bitch, afe pr7, magnaflow, Kennedy lift pump, dual rail mount filters, PPE tunes
00 f350 srw rc=6100lbs
ats comp housing,bdp 1.0 exhaust,afe pr7,4in turbo back magnaflow,hx cross,di regulated return,bbha,dp hi,40,80e,120r,6.oh no cooler autometer gauges, dual rail mount filters
bigd4me2 is offline
post #4 of 16 (permalink) Old 06-12-2008, 08:45 AM
BUFF's Avatar
06 F350 CC LB 4x4 with a few odds and ends
BUFF is offline
post #5 of 16 (permalink) Old 06-12-2008, 11:27 AM
JDG's #1 Fan
99F250Smitty's Avatar
Send a message via AIM to 99F250Smitty
May be a dumb question, but where might one get this Royal Purple?
Brian
_____________________________________________
99.5 F250 Extended Cab Short box. 4x4.
99F250Smitty is offline
post #6 of 16 (permalink) Old 06-12-2008, 04:14 PM Thread Starter
Soon to be a 6.4
lildevil02's Avatar
Napa, Summit and jegs carries the full line.
I think thats what I'm going to run.
post #7 of 16 (permalink) Old 06-12-2008, 04:26 PM
fastpowerstroker's Avatar
Royal Purple here with no Friction additive. The local Pepboys has it and also NAPA.
2003 F350 7.3l, 60Kmi, XLT, CC, LWB, SRW, 4X4, 4R100, 3.73LS. 4" BDS lift w/315/75/R16 BFG at's on Mickey Thompson classic II wheels. Isspro gauges, Mag-Hytec tranny pan, B&M tranny cooler w/fan. Line-X bedliner. Firestone air bags.
fastpowerstroker is offline
post #8 of 16 (permalink) Old 06-12-2008, 04:46 PM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
Order up the 08 cover and gain a little cooling for a little cash...
Joe
CSIPSD is offline
post #9 of 16 (permalink) Old 06-13-2008, 12:03 PM
JDG's #1 Fan
Are you guys running different weight oils in the front and back?
Brian
post #10 of 16 (permalink) Old 06-13-2008, 08:21 PM
Proud PSN Sponsor
Deputydog's Avatar
Yes..
75W/140 in the rear and 75W/90 in the front.
820 HP on 05/19/12
Toll Free 866-379-8685
Deputydog is offline
