Burning WMO... - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 40 (permalink) Old 06-03-2008, 10:59 PM Thread Starter
Hoosier daddy!
Ramblin'_Man's Avatar
Burning WMO...
I want to start burning my WMO and tranny fluid. I don't stockpile it so I will be storing it in a 5 gal kerosene can. What is a good, inexpensive way to filter the oil before I dump it in the tank? I want to burn the stuff, I don't want to clog up any of my filters unnecessarily though. I'm not worried about ruining injectors, I have an airdog pre pump filter and the filter bowl still in place so there is plenty of filter media bewteen the crud and my engine.
2001 PSD F250
Born 4/01 in KY USA,
4x4, 3.73, Ext. Cab, Shortbox...
ITP RR, CCV, Tymar Intake, Airdog, DP tuner
Ramblin'_Man is offline
post #2 of 40 (permalink) Old 06-03-2008, 11:02 PM
OBS junkie
Cat_Rebel's Avatar
Re: Burning WMO...
PM Kainers he runs alot of it in his Stroker.
97 F350 CCLB "Da Bus"
RIP Will Iott
"This ain't no practice run"
Cat_Rebel is offline
post #3 of 40 (permalink) Old 06-03-2008, 11:16 PM
Cummins Power
mech2161's Avatar
Re: Burning WMO...
I have a threaded hand pump with a filter housing on the outlet then the hose. I'm using a 6 micron filter. I have another guy using it also.
Kevin
12v CONVERSION IN PROGRESS, Special thanks to:
South Bend Clutch, MOTORSPORTSSUPPLY.COM, Pure Diesel Power & Performance, Carson Stauffer Diesel Service, Weston Shupe, zstroken
mech2161 is offline
post #4 of 40 (permalink) Old 06-03-2008, 11:52 PM Thread Starter
Hoosier daddy!
Re: Burning WMO...
Maybe a dumb question, but by a "threaded" hand pump, you mean a hand pump that has a threaded end on it that you can screw the filter housing to? If that's the case I may be able to whip together something like that in no time.
2001 PSD F250
post #5 of 40 (permalink) Old 06-03-2008, 11:53 PM
DILLIGAFF
Send a message via AIM to Redfish
Re: Burning WMO...
yep... i pre mix it with diesel first, then filter it.
2006 F-250 CC King Ranch, Harley Headlights w/ 55w HIDs
ARP studs, MBRP 4" exhaust and AM Colbalts By:
, AFE stg. 2 Pro Guard 7 from XDP, SCT from innovative!
14.09 @ 94 1.85 60'
Redfish is offline
post #6 of 40 (permalink) Old 06-03-2008, 11:53 PM
Cummins Power
mech2161's Avatar
Re: Burning WMO...
Yes!
Kevin
mech2161 is offline
post #7 of 40 (permalink) Old 06-04-2008, 12:01 AM Thread Starter
Hoosier daddy!
Re: Burning WMO...
Yes!
Do you recall where you found that pump, or is it something you made? I've been looking around on the interweb but didn't see anything off hand that looked like what you were talking about. But the idea is easy enough that I could gather up a few fittings and what not and put a little pump assembly together.
2001 PSD F250
post #8 of 40 (permalink) Old 06-04-2008, 12:43 AM
Cummins Power
mech2161's Avatar
Re: Burning WMO...
NAPA
Kevin
mech2161 is offline
post #9 of 40 (permalink) Old 06-04-2008, 01:04 AM
utah get me two
Re: Burning WMO...
have things changed ??? i have read alot of threads by many of the folks that frequent here,and dumpiny anything like mortor oil was no no.due to the very tight tolerences in our enjectors...
a thread from this site next page from here
https://powerstrokenation.com/forums/...ead.php?t=2449
[SIGPIC][/SIGPIC]2001 f250 4x4 cc sb 6 in lift...dp 6 pos..
glamis_dave is offline
post #10 of 40 (permalink) Old 06-04-2008, 04:14 AM
Starting Over
kainers's Avatar
Re: Burning WMO...
Veggie oil no WMO but I collapsed my threaded hand pump filter due to the viscosity of the oil.So Premix prior may dilut the veggie.
Jizzy don't like tranny fluid.I poured six gallon into her and she did not run right knocked hard and smoked.Don't know why just didn't run right.I have ran over 75 gallons of motor oil in her.One tank was 95% easy.The rest about 50%.I haven't had any issues.It will leave a white chalky residue in your tail pipe.It will also smoke white wisp.
kainers is offline
