changing my power steering fluid - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 08-19-2011, 02:56 AM Thread Starter
so many trees
sargepep56's Avatar
my truck is making that awsome whine when i turn the steering wheel. this leads me to believe that my power steering fluid has gone bad. i checked the fluid and it is dark brown and smells burnt.
my question is how do i change it. i have never done this before and dont have the spare cash to take it to a mech to change it.
thanks for the info
some stock truck from washington state
sargepep56 is offline
post #2 of 5 (permalink) Old 08-19-2011, 02:48 PM
Exploding the magma
rufushusky's Avatar
Re: changing my power steering fluid
thanks for the info
Ford Super Duty Power Steering Flush | Superdutypsd.com
Good write up in the link above.
2002 F-350 ECLB SRW 7.3 4R100
6637 203* t-stat 08 diff cover Stancor HPX 6.0 trans cooler, Zone offroad leveling kit, Western UM 8'6" plow
Sold: 2004.5 Ram 2500 w/ 5.9 CTD, Reg Cab 48re
rufushusky is offline
post #3 of 5 (permalink) Old 08-21-2011, 01:08 AM
SyN
Lubrication Addict!!
Sarge: Ruf posted you the best flush method... Takes about 20-30min... Use 4qts ATF...Use all 4qts... you will waste about 1qt... but you want to make sure all that old ATF is out of there... I just did this flush 2wks ago... just make sure you raise the front end where the front tires are off the ground... Have one person pump brakes and turn steering wheel from corner to corner, while you keep resiviour full and keep on eye on the old ATF going into your drain jug and fresh ATF coming out of Hydroboost...
2001 F250 XLT CC 4X4 AUTO SWB
{295K miles}.
Donaldson AIS Intake w/ZooDad
4" MBRP Turbo Back Exhaust.
DieselSite By-Pass Coolant Filter/{ELC}&RMI-25
DieselSite By-Pass Transmission Filter/Lg Magnet
Delete Mods-->{Foil & AIH}
203*{T-Stat}w/Billet Housing
SS HPX line-CCV{to atmosphere}
Marinco Heater Plug
Oil-->T6 5W-40 w/Amsoil Filter
SyN is offline
post #4 of 5 (permalink) Old 08-21-2011, 02:05 AM
Administrator
Zmann's Avatar
it's easy for one person also because without brake or steering input no fluid flows so get a long hose and a bucket you can monitor how much comes out and refill at intervals
just set your parking brake and you don't even need to sit in the truck
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #5 of 5 (permalink) Old 08-21-2011, 06:58 PM
SyN
Great Thinking Z: I like the shorter hose-->Less fluid in line=Less mess for myself... No matter how hard I try to keep everything nice and clean{spill free} $hit just seems to happens to me...
{295K miles}.
Marinco Heater Plug
SyN is offline
