Schaffer Oil - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 05-29-2008, 08:35 PM Thread Starter
Schaffer Oil
What has been your experience with this oil? I understand if you buy 500.00 dollars worth of oil then you can get free oil analisis from Schaffer. A 55 gallon drum of Schaffers is over 200 dollars more than rotela, or more depending on which oil you purchase. I am trying to decide if the extra cost is worth it considering the free oil analisis.
99.5 F-350 SRW 6 speed mods:PHP live tuned., MSD propane system, snow water injection,DDP stage 1 injectors,AFE stage II air intake,ITP boost regulater,3.5 turbo back exaust,FASS fuel system. Gulf Coast oil bypass filtration, ITP reg. return, HPX oil line , GTP 38r with 1.15,EBPV delete. 430,000 miles,Adrenaline HPOP
cantrellc123 is offline
post #2 of 8 (permalink) Old 05-30-2008, 12:08 AM
Wheelie Dude
bean's Avatar
Send a message via AIM to bean
Re: Schaffer Oil
With a drum you get three oil sample bottles as long as you ask for them.
The 7000 is way better then anything Rotella has to offer not to mention you can go much longer on change intervals making up for the extra 200.0.
Smokin' Hot Hooker- 2002 F350 Dually 4x4 6spd- 5.9 CR-
BDP Drag Truck- 81 C10-5.9CR, BTS 4R, Goes Fast
Beans Diesel Performance
bean is offline
post #3 of 8 (permalink) Old 05-30-2008, 05:21 AM
Freedom is not free
White Buffalo's Avatar
Re: Schaffer Oil
I average 7,500-8,500 between oil changes with Schaeffer's series 7000 15W-40 with an oil analysis.
Also, any order over $300 will also get you free shipping.
The price won't be as different soon, Shell will have another 15-18% increase come 31 May.
White Buffalo is offline
post #4 of 8 (permalink) Old 06-01-2008, 10:45 PM
Non Helpful Member
Deerezilla's Avatar
Re: Schaffer Oil
We run it in all the equipment. I used to run dello 400 100hr on the equipment now with Schaeffer's we go 250hr with great oil samples. I have been going 5000 miles on the trucks with Schaeffer's 7000
2 fords that make no power
Deerezilla is offline
post #5 of 8 (permalink) Old 06-02-2008, 12:29 AM
Bleau May
Soaggydogg's Avatar
Re: Schaffer Oil
Why only 5000 miles on the trucks, lots of hours?
02 Excursion foil delete and a Tapercore
Soaggydogg is offline
post #6 of 8 (permalink) Old 06-02-2008, 03:49 AM
Freedom is not free
Re: Schaffer Oil
If I read his signature correct he has TE's Big Oil on two of those trucks. That will shear the oil quicker than the stock HPOP setup. With dual pumps running high ICP you can easily see most oil drop below 13.0 CST sooner.
Soaggy,
What dual HPOP system is on the dually you just bought. It's oil analysis showed it maintained 13.55 (40 weight oil) at 4,500 miles on Schaeffer's. The last sample looked pretty good for the mods on the beast........
post #7 of 8 (permalink) Old 06-02-2008, 01:13 PM
Bleau May
Soaggydogg's Avatar
Thumbs up Re: Schaffer Oil
That'd be the Stealth and he wasn't running 3900 icp or whatever it is.
post #8 of 8 (permalink) Old 06-02-2008, 01:42 PM
Non Helpful Member
Deerezilla's Avatar
Re: Schaffer Oil
[QUOTE=Soaggydogg;194699]Why only 5000 miles on the trucks, lots of hours?[/QU
lots of idleing time.
