Howes Diesel Treat. - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 06-17-2011, 01:18 AM Thread Starter
97Powerstroke Boy's Avatar
Howes Diesel Treat.
I just picked up a bottle of Howes Diesel Treat and was owndering if anyone else here runs it. Ive heard good things about it. I was running CenPeco additive and it worked great and may go back to it, but it was $8.00 a bottle and only treated 50 gallons a bottle, over the Howes that cost $13.00 a bottle and treats 320 gallons.
Sean
1997 Ford F250HD XLT RCLB
Spectre air intake
3" Downpipe-dual 5" Aussie Stacks
Boost, Tranny Temp, and EGT Glowshift guages.
TS 6-pos chip with TS tunes for now.
33" Kelly Safari Tires on stock alcoas.
Custom front bumper and fender
97Powerstroke Boy is offline
post #2 of 11 (permalink) Old 06-17-2011, 03:54 AM
Need a ride.
Strokerstooge's Avatar
Re: Howes Diesel Treat.
I've ran it once or twice, the motor seemed to quiet up some but for 2 or 3.00 more the Diesel Kleen did a better job for me, better pep on the DK.
03 F-250 7.3 XLT CC SB Auto 38R, S-B Intake, 4 inch MBRP Duals, Regulated Return, J Wood VB, DP Tuner, Isspros 3 Pillar, Terminator Scan Gauge, DS Coolant Filter, HPX
Strokerstooge is offline
post #3 of 11 (permalink) Old 06-17-2011, 04:15 AM
lincolnlocker's Avatar
I've tried a few. And power services white bottle works the best for me. I run it year around.
00,f350 lariat,4x4,cc,drw,38r,bdp stage 2/170cc/100s,bdp live tunes,4''down 5''back,dieselsite adrenaline,diy RR w/walbro,bellowed uppies, BTS trans!
01, rclb, 4x4, zf6, caned ts tunes, xl work truck package, 4'' tbe
lincolnlocker is offline
post #4 of 11 (permalink) Old 06-17-2011, 06:06 AM Thread Starter
Thanks guys. Like I said I might go back with the Cen-Pe-Co since it did the job quite good.
Sean
Spectre air intake
post #5 of 11 (permalink) Old 06-17-2011, 10:58 AM
Howes is pretty decent stuff. A ton of owner/operators use it all the time.
2000 F-350
jff987 is offline
post #6 of 11 (permalink) Old 06-17-2011, 11:22 AM
FNG
Dave's Avatar
Howes sucks. I ran my first and last bottle over the last 3 weeks.
Figured I would try it since its cheap. Now I know why its cheap
Im going to go exclusively with the Rev X additive or the stanadyne
Dave G
06 F250 Lariat 4x4 leveled on 35s
4 inch flowmaster exhaust
Bulletproof diesel egr delete.
Bulletproof diesel FICM
Performance Machine & Manufacturing Coolant Filter Kit
ECM and FICM tuned by Bill at PHP SCT tunes from Gearhead, Innovative and Wildman
Dave is offline
post #7 of 11 (permalink) Old 06-17-2011, 02:10 PM
Running at last...
powerstroke cowboy's Avatar
I like the Powersevice stuff in the gray bottle better then anything I have every tried..
BUT i use Howes in the winter to keep from gelling. I have NEVER had a gelling problem when I use Howes diesel treat, Even when we hit -40 F (and lower) Without the wind chill!!!
To tell the truth I run Howes and Power sevice diesel treat in the winter AT the same time.. It canr hurt a thing I use PS for Milage and Howes to keep from gelling.
Another thing to remember Howes diesel treat will PAY TO HAVE YOUR PICKUP TOWED if you gell when using there product..
97 CCLB 4x4 ZF6 [email protected]
powerstroke cowboy is offline
post #8 of 11 (permalink) Old 06-20-2011, 02:34 AM
SyN
Lubrication Addict!!
Local trucking company passed alot of info on too me about a product they had been using for the last 2yrs...They have kept track of every detail...via computers in the trucks... downloading them within spreadsheets... showing very impressive results, as well as not one jelling problem... Granted a Semi Truck driving habits are different then a normal pickup, but I hope the results are somewhat similar... It's worth a try...
The company used the recommend dosage...Ratio Mix 1000:1
Diesel Fuel Additives - Diesel Fuel Conditioner, Lubricity, Treatment
I have also used White P/S during the winter months-{Never Gelled Up}
I have never had a Gell problem with Howes
My Problem I guess is I'm always open to try different products... {OutSide the Box}.
2001 F250 XLT CC 4X4 AUTO SWB
{295K miles}.
Donaldson AIS Intake w/ZooDad
4" MBRP Turbo Back Exhaust.
DieselSite By-Pass Coolant Filter/{ELC}&RMI-25
DieselSite By-Pass Transmission Filter/Lg Magnet
Delete Mods-->{Foil & AIH}
203*{T-Stat}w/Billet Housing
SS HPX line-CCV{to atmosphere}
Marinco Heater Plug
Oil-->T6 5W-40 w/Amsoil Filter
SyN is offline
post #9 of 11 (permalink) Old 07-06-2011, 03:50 AM
Mother of God!!
I run howes in mine during the winter months and when its -50 out there is bound to be problems but i havent had any gelling with howes products, and as said before, they weill pay for the tow if it was to gel up
SMOKE&STROKE is offline
post #10 of 11 (permalink) Old 07-19-2011, 06:46 PM
I run Howes year round it is great stuff, helps lube the injectors and keeps from gelling in the winter. I have unthawed many diesels in the winter that run other treatments but never once had one running howes gel up. My dad has been an otr driver for 20+ years and howes is the only additive he will run, his trucks have always started when it is -20 or below and not plugged in, you do have to mix it at their recommended ratio though.
MTdiesel is offline
