jet fuel - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 34 (permalink) Old 05-11-2008, 11:52 PM Thread Starter
mjones's Avatar
jet fuel
has anyone ever ran jet fuel in their trucks I have chance to buy some for cheap but am not sure how well it would do in a truck
mjones is offline
post #2 of 34 (permalink) Old 05-12-2008, 12:01 AM
Banned
Re: jet fuel
I know on my Deuce and a Half it lists Jet-A as a fuel that can be burned, but also shows a mixture of it and engine oil for lubricity I assume.
The Jet-A might not have enough lubricity for the diesel injection system without an additive.
That's a guess of mine based on the Milspec for running it in the army truck.
Charles is offline
post #3 of 34 (permalink) Old 05-12-2008, 12:04 AM
OBS junkie
Cat_Rebel's Avatar
Re: jet fuel
We have a member that is just starting to do it on here. You'll have to mix it with 2 stroke oil though.
Don't go around telling everyone that you are running it either, somone may not like that too much.
97 F350 CCLB "Da Bus"
RIP Will Iott
"This ain't no practice run"
Cat_Rebel is offline
post #4 of 34 (permalink) Old 05-12-2008, 12:04 AM
DILLIGAFF
Send a message via AIM to Redfish
Re: jet fuel
run it, add about 1-2 oz of walmart 2 stroke oil per gallon.
2006 F-250 CC King Ranch, Harley Headlights w/ 55w HIDs
ARP studs, MBRP 4" exhaust and AM Colbalts By:
, AFE stg. 2 Pro Guard 7 from XDP, SCT from innovative!
14.09 @ 94 1.85 60'
Redfish is offline
post #5 of 34 (permalink) Old 05-12-2008, 01:33 AM
SUPERDF350's Avatar
Re: jet fuel
I have ran about 500-600 gallons of Jet-A in my truck. I was mixing Marvels in it for the longest time, but with the cost of Jet and marvels I was not saving to much. Then I started using 2-stroke and i made it alot cheaper. But now jet is alittle cheaper the #2. Jet-A is very dry compared to #2. In for 20 gallons i would add 12 oz of oil to it. Egts seemed to be a little higher but it may have been me looking to hard. The cool thing is the smell. Smelt like you were at an airport. Im getten nerivos with all the fuel issues. I dont want someone to dip the tank.
2003 F-350 CCLB 4x4 6 spd man 5.5 Fabtech, 4"turbo stright piped,DP Tuner, hi-idle,40,60,80,100,120, ATS housing wicked wheel, tymar intake,firestone airbags.
SUPERDF350 is offline
post #6 of 34 (permalink) Old 05-12-2008, 02:36 AM
Banned
Re: jet fuel
The truck should run cooler on the Jet-A. It should also NOT smoke. Hence the reasons that you don't run #2 in a Gas turbine setup for Jet-A. It would roll coal and melt down..... but make a good bit of power.
Jet-A has less BTU per gallon IIRC. So with a constant injector capacity, the truck should make less power.
Charles is offline
post #7 of 34 (permalink) Old 05-12-2008, 03:08 AM
Above It All
Cool Canuck's Avatar
Re: jet fuel
Jet A is kerosene. You can burn it but your truck might not like it. Mine would rattle and cackle so bad I couldn't bring myself to burn it. And that was mixing 5 gal into a tank of #2. Doubt it would do any harm.
Jet B is cut with gasoline/naptha. It might really be hard on pumps and injectors.
'01 F250 SC/SB 4X4 Trailer Tug
Cool Canuck is offline
post #8 of 34 (permalink) Old 05-12-2008, 03:13 AM
<----Colin Banks
mattymx's Avatar
Re: jet fuel
As Ryan stated, he was running Jet-A for a while. But what I would do if running it would be to actually double the 2 stroke oil. Mix it at 2oz/gallon and that would bring the HFRR rating within spec for our engines. Jet-A also is lower in BTU than #2 so you will lose a little MPG.
mattymx is offline
post #9 of 34 (permalink) Old 05-13-2008, 10:52 AM Thread Starter
mjones's Avatar
Re: jet fuel
hey thanks for the help guys let you know what happens
mjones is offline
post #10 of 34 (permalink) Old 05-13-2008, 01:42 PM Thread Starter
mjones's Avatar
Re: jet fuel
i think the fuel is J8 or jet8 now is there any suggestions?
mjones is offline
