03 7.3 Excursion high pitched sound? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 09-15-2019, 11:41 PM Thread Starter
Hey all,
I was running my 03 Excursion today coming home from northern Michigan pulling our 33' Jayco trailer when the transmission downshifted while going up a hill and at 3000 rpm there was a high pitched , I don't know if I would call it a squeal but it sounded very metallic. The instant that the transmission up shifted and the RPM's went down the squeal went away. It did this twice. I'm wondering turbo or transmission?
Last year I put a Mishimoto oil cooler on the trans and it had a full flush and filter change about a month ago. Along with new engine oil, filter and I put on one of those hpop crossover tubes in it as well. The camper is about 6500-7000 lbs. The truck has been cared for meticulously by myself and the one previous owner. 245k miles. Is this too vague of a description to the noise or has someone else experienced it also?
tzolk is offline
post #2 of 7 (permalink) Old 09-15-2019, 11:44 PM Thread Starter
I forgot to add, the sound to me was coming from the back of the engine, behind the dash area, not from down below.
tzolk is offline
post #3 of 7 (permalink) Old 09-16-2019, 11:55 AM
Moderator
Sbluke55's Avatar
Re: 03 7.3 Excursion high pitched sound?
Check to see if the exhaust is hitting the frame anywhere. Also check for soot on the up pipes.
01 f-250, Standard
Sbluke55 is offline
post #4 of 7 (permalink) Old 09-18-2019, 01:45 PM
410customs's Avatar
Was it a turbo noise??
My excursion has made this metallic turbo wheel noise a couple of times while towing, just like you describe
The turbo on our excursion has also been known to "flutter" under load on long grades at higher boost.
I figure the turbo needs to be rebuilt
The sound to me sounds like the compressor wheel rubbing the housing!!!
I have yet to look in there....too many projects the excursion will have her day.
Very metalic sounding, exactly as you describe, happens when downshifting and towing long grades under boost......first time I thought "OH CRAP there goes the turbo"
Year later happened again I'm like "Oh crap there goes the turbo"
Third time I'm like "ah well she just does that sometimes."
Borrowed time, a noise like that is not normal operating proceedure
2001 Excursion 7.3, auto, 4x4, 3.73, 6" Suspension lift, 37" Dick Cepeks
2000 E350 7.3, auto 2wd, 3.73, planning a TTB 4x4 conversion
21.9 liter family
410customs is offline
post #5 of 7 (permalink) Old 09-20-2019, 01:50 AM Thread Starter
This---^ That is exactly what I experienced! We were going up a grade when the truck downshifted and the metallic whine sounded like the turbo does at times in tone (light tone) but this time it was LOUD. Exactly like something was scraping as you described. I haven't heard it while just driving and my wife didn't hear it last year when she towed the camper up multiple mountain passes in it while following me in the moving truck. Good to hear you haven't had any further issues since you've experienced it. If it is the turbo, I wonder if it may need a whole new one in the future or it could be rebuilt in the garage at home.
tzolk is offline
post #6 of 7 (permalink) Old 09-20-2019, 02:14 AM
Project Shamu
Lt.Dan's Avatar
The 7.3 turbo is fairly easy to rebuild at home and just requires a couple of not so special tools.
1996 Cali F350 CCFB, 7.3 PSD, 2wd SAS, w/ 378,000 miles.
New Motor at 352,000, DieselSite Legendary Trans at 356,000 and many more
Lt.Dan is offline
post #7 of 7 (permalink) Old 09-20-2019, 01:52 PM
410customs's Avatar
rebuilt it
I have rebuilt 5 or 6 of them now
It takes longer to remove it then it does to rebuild it
I need to rebuild the one in our Excursion also
You may remove the air intake tube and have a look see make sure the compressor wheel is still tight on the shaft and not "out of round" or bitched up
It should have a slight amount of in and out play but almost no up and down
I actually really enjoy rebuilding these turbo's
21.9 liter family
