AE won't show values - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 04-25-2011, 04:55 PM Thread Starter
Busted Knuckles
PSDEng's Avatar
I purchased AE a few months ago. I first connected it to my truck and everything worked fine. Randomly the live data meter readings started reading all zero values for me. I called AE and they worked with me and determined that I had a bad connector so they shipped me a new one. I tried hooking it up to my truck and the live data meters are still only reading zero. I also can't perform any KOER/KOEO tests. The strange thing is I can use the software on a couple other trucks perfectly. What could be the problem with my truck?
'97 Powerstroke SCLB:
i have a couple friends that went balls deep in wyotech and when they got out they couldn't poor piss out of a boot if you put the directions on the sole
PSDEng is offline
post #2 of 6 (permalink) Old 04-26-2011, 05:56 AM
FORD..THE ROCK CRUSHER
Ron's power stroke's Avatar
Re: AE won't show values
does your cigarette lighter work?? if not check the fuse...the same fuse powers the OBD port..
Ron's power stroke is offline
post #3 of 6 (permalink) Old 04-26-2011, 11:10 AM Thread Starter
Busted Knuckles
PSDEng's Avatar
I'm getting power to the port, the software is connecting to my truck and detecting all of the sensors, but they just read zero values all the way across the board! It's really confusing!
PSDEng is offline
post #4 of 6 (permalink) Old 04-28-2011, 06:50 PM Thread Starter
Busted Knuckles
PSDEng's Avatar
Any other suggestions?
PSDEng is offline
post #5 of 6 (permalink) Old 04-30-2011, 01:20 AM
R.I.P
SDS97_7.3's Avatar
Sorry I don't have any ideas but same thing happened to me every other time i hooked it up. But when doing some work I had my batteries unconnected for a while and after that it worked fine (knock on wood). Could have been coincidence though. Hope you get it worked out
1997 F350 7.3 Powerstroke, 4x4, 135,400 miles, 4 1/2" up front 2" out back, 35" Kuhmo M/T's, 3" dp, 4" with no cat, K&N, Triple Auto Meter Gauges, IDM Mod, rebuilt E4OD, Beans Tunes
SDS97_7.3 is offline
post #6 of 6 (permalink) Old 02-23-2015, 08:57 PM
I have the same problem early 99 7.3 got dtc codes, but no live data and the onboard test system doesn't appear to work
Hotrodd64 is offline
