Bad bearing or Camber off? - PowerStrokeNation : Ford Powerstroke Diesel Forum
 6Likes
post #1 of 15 (permalink) Old 04-11-2019, 01:58 PM Thread Starter
Popojoe's Avatar
🧐 ok all I need help. Got this 93 7.3 2wd idi all stock, run great. Alignment is good to go, no wandering, tie rods are firm, no play when I lift the truck and try to move the tire.
Heres my problem, when driving between 60 to 65-70 mph, I feel my driver front tire "shaking" . It only occurs around those speeds. I've also noticed outside tire wear on the same tire only. I dont feel any cupping, just a slight feathering on the outside edge of that tire. All others are running fine, no push back on brake pedal, alignment stays straight. No pulling or excessive play in steering. I do notice a wobble when turning right only, not left.
I thought camber at first but I'm more inclined to go with the bearing. Just got done paying taxes don't want to start blindly throwing money into it.
How can I check camber in the garage? If it's a bearing how do I check it for play? I lifted the truck and tried to check for wheel play but guess I'll have to remove tire and see if I have pay in the bearing?
Thank you in advance for input.
Popojoe is offline
post #2 of 15 (permalink) Old 04-11-2019, 04:31 PM
don't play well w others
Dustybumpers's Avatar
Re: Bad bearing or Camber off?
Cupped tire is either a bad shock, bad tire balance, or tire out of round because tire core seperation
Charlie
"A common mistake people make when trying to design something completely fool proof, is to underestimate the ingenuity of a complete fool like me."
Dustybumpers is offline
post #3 of 15 (permalink) Old 04-11-2019, 05:31 PM
HilhavenFarm's Avatar
I have this now on a Jeep, I know my issue is balance, a weight is missing.
How old/miles on tires?
1996 F350 XL Crew Cab LB 4x4 3:55
Former Ft. Bragg/Pope AFB Truck
DieselSite Coolant Filter
Riff Raff Diesel Turbo & Y Boot Kit
Riff Raff Diesel HPX
Mile Marker 449SS Manual Hubs
1987 F250 XLT Lariat LB 2WD 4:10
6.9/7.3 IDI Swap-SOLD
2010 John Deere 5055D
1974 Deutz 5506
2950 hours-"The Tank"
HilhavenFarm is offline
post #4 of 15 (permalink) Old 04-11-2019, 06:13 PM Thread Starter
Popojoe's Avatar
Tires are almost new came with the truck which I bought about a month ago, despite the tire in question they still have about 5/8 off an inch of meat on them. Like I said I don't see or feel any cupping going on. Just wearing on the outer edge of the driver side tire and the wonky feel at the speeds or the slightest wheel movement left.
Was asking around guess I'll swap the front tires side to side and see if the problem changes to the other side then I can narrow it to the tire.
Popojoe is offline
post #5 of 15 (permalink) Old 04-11-2019, 06:15 PM Thread Starter
Popojoe's Avatar
Correction I meant feeling wonky with slightest wheel movement to the right. Left feels smooth and fluid.
Popojoe is offline
post #6 of 15 (permalink) Old 04-11-2019, 08:02 PM
Master BS'er
jamiesaun's Avatar
All you can do is Jack up the front and check everything. Check bearings, ball joints, track bars, rods and gear. if everything is tight then it will need an alignment check. Shake at three and 9 for steering stuff, 6 and 12 checks bearings and ball joints
Just because it doesn't pull or wander doesn't mean the alignment is good. It's pretty rare for solid axle stuff to go out in camber or caster if the parts are tight. But it can happen, there's shims for it. Could also be a toe wear, and toe doesn't cause a pull, unless it's way off.
Can't be checked in you're driveway, not without a bubble gauge and those suck anyway.
Brother James
Ps...Im pretty frickin awesome!
jamiesaun is offline
post #7 of 15 (permalink) Old 04-11-2019, 08:32 PM Thread Starter
Popojoe's Avatar
Thanks I'll swap the two front tires to see if there is any change, if not then I'll have to get the alignment after double checking the bearings again. I follow up after I get the alignment done, thanks for input. I check back in
Popojoe is offline
post #8 of 15 (permalink) Old 04-11-2019, 08:41 PM
alleged moderator
tjctransport's Avatar
i have to agree with Charlie on this one, it sounds like that tire is out of balance .
tom
tjctransport is offline
post #9 of 15 (permalink) Old 04-12-2019, 03:37 PM
Swapping radial tires side to side without turning them around on the wheels is a recipe for disaster.
It will cause the tire to separate inside.
tjctransport likes this.
Charlie
post #10 of 15 (permalink) Old 04-19-2019, 12:06 AM Thread Starter
Popojoe's Avatar
Thanks for all your input. Just got back from shop. Turns out that was a bad tire, someone tried to balance it I guess when installed and there was so much weight that it looked like it covered half the rim. You could also see where a few weights had fallen off. Luckily I had good enough credit was able to get 2 new financed, and now the ride is smooth as butter no more wobble.
tjctransport and aussamdad like this.
Popojoe is offline
Similar Threads
Little video of a 76mm ball bearing charger VS. stock journal bearing 08BIGRIG 6.4L Power Stroke - Aftermarket & Performance 0 01-23-2014 11:00 AM
Back to the turbo bearing subject...any bearing kits better/worse than others?? Kentuckydiesel 1994-1997 OBS Power Stroke - Aftermarket & Performance 3 07-24-2013 08:25 PM
93 Ford IDI Camber off after Add-a-leaf mn_lineman Suspension and Drivetrain 1 04-01-2010 01:44 AM
Engine Fan----On off, on off, on off, on off Ford-Willy 7.3L Power Stroke Technical Info 5 05-01-2009 01:38 PM
Benefits of ball bearing vs journal bearing jeromejcp 7.3L Power Stroke - Aftermarket & Performance 3 08-21-2008 02:35 AM
