Best Towing Mirrors For A 1995 F350? - Page 4 - PowerStrokeNation : Ford Powerstroke Diesel Forum
 6Likes
post #31 of 42 (permalink) Old 10-30-2017, 04:46 PM
Re: Best Towing Mirrors For A 1995 F350?
Originally Posted by 410customs View Post
IMO best setup is:
or even better this setup:
I like this setup. Any more pictures or description of it? I like that it uses the original mounting plate. I am concerned how much vibration there will be with the extra weight hanging on it.
96 F250 CCSB 4x4, D60, 3.55, Auto, 6.0 trans cooler 3"-4" down pipe & exhaust, not enough power
wildstang is offline
post #32 of 42 (permalink) Old 01-29-2018, 04:02 PM
HilhavenFarm's Avatar
I prefer a factory look. I upgraded from the T-Rex mirrors to these. I could not see around my trailer with the small ones.
1996 F350 XL Crew Cab LB 4x4 3:55
Former Ft. Bragg/Pope AFB Truck
DieselSite Coolant Filter
Riff Raff Diesel Turbo & Y Boot Kit
Riff Raff Diesel HPX
Mile Marker 449SS Manual Hubs
1987 F250 XLT Lariat LB 2WD 4:10
6.9/7.3 IDI Swap-SOLD
2010 John Deere 5055D
1974 Deutz 5506
2950 hours-"The Tank"
HilhavenFarm is offline
post #33 of 42 (permalink) Old 01-31-2018, 02:45 AM
Tmcpherson's Avatar
What about these.
https://www.ebay.com/i/282441759839?chn=ps
Tmcpherson is offline
post #34 of 42 (permalink) Old 10-03-2018, 11:14 PM
m j
m j's Avatar
an 8" convex is the best towing mirror.
1997 F250 rclb 4x4,Comp910s,SRP1.1,Irate T4 s468,FullForce 350/200,efuel A1000 5/8" drawstraw,DI fuel fittings,D60f Detroit,Grizzly10.25,windowed 7.3 Oct 9/14
rebuild .010 riffraff cut pistons,swamps fire ring kit,Girdle,high-filled block,Manley rods,SBC dualdisc,ATI dampner,MorelLifters,MantonPushrods,ColtCam,
m j is offline
post #35 of 42 (permalink) Old 05-06-2019, 07:26 AM
like the gooseneck mirror for a dually and hauling a box trailer.
martinbrown283 is offline
post #36 of 42 (permalink) Old 05-14-2019, 02:07 AM Thread Starter
I'm curious about this one too: but does anybody have any more information on it?
At this point I need to swap out my flag mirrors, so I was thinking about going with 2 point mounts and gooseneck mirror heads.
BreakAes is offline
post #37 of 42 (permalink) Old 05-14-2019, 02:24 AM
Native Texan
masakimm's Avatar
Garage
Well I saw that one when I did my looking never could find any info on it but from said looking it appears to be a custom door mount using a modified chevy mirror. I went with the weld on brackets that let you use the 2006 and older mirrors from chevy. vent windows still work.
I was born into Gobernment health care. And will die in Gobernment Health care. God Bless Our Military Men And Women.
Upgrades:
masakimm is offline
post #38 of 42 (permalink) Old 05-14-2019, 02:41 AM Thread Starter
Thanks for the info. I'll probably go with the 2 point mounts with gooseneck mirror heads, since people seem to like that setup, but I haven't been able to find any OEM mounts when I called the local junkyards.
If anybody knows where I can source quality 2 point mirror mounts, let me know, thanks.
BreakAes is offline
post #39 of 42 (permalink) Old 06-07-2019, 02:35 AM Thread Starter
I ended up getting a couple 2 point mirror mounts with Extend-A-Mirror Arms, and 1 gooseneck mirror, and 1 regular mirror from a junkyard a few towns over.
For now, I plan on trying one side with just the gooseneck mirror, and the other side with the regular mirror on the Extend-A-Mirror Arm. Any thoughts on which mirror is better for which side during this test? Once I decide which setup I like better, I may put the same mirrors on each side, or keep things as they are if it's working fine.
Also, I found a video on removing the flag mirrors from a 1995 truck:
but is there a guide, or any tips, advice, etc., on installing the 2 point mounts, especially since you need to drill 2 holes per door for the lower part of the mount? I want to get them installed right the first time without messing anything up. The only advice I've gotten so far is to use jack nuts for the lower part of the mount.
Thanks
BreakAes is offline
post #40 of 42 (permalink) Old 06-07-2019, 02:39 AM
Native Texan
masakimm's Avatar
Garage
Anti-sieze is ur friend. I would also washer the mounts if U can find a washer the right size I would put it on the riv-nut before locking it down to distrubute the load out more but that's just my opinion on the matter.
Upgrades:
masakimm is offline
