Tips on kinda building a obs 7.3 motor - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 2 (permalink) Old 10-11-2019, 12:30 AM Thread Starter
Hi yall well the times come and I'm rebuilding the spare motor I have and have a few questions. I'm looking to have food longevity out of the motor and already have moderate performance stuff on the current motor, 180/100 injecters, t500 hpop, irate t4 kit with s369sxe, Tony Wildman tunes on a ts6, clutch, 6.0 Intercooler, dual Bosch pump diy e fuel, 6637 air filter and 4in straight pipe exhaust. I've got push rods, valve springs and studs already for the motor I'm rebuilding but I'm wondering if I should replace lifter, valves and get a girdle even though I'm still running stock rods. Looking at a mahle stock rebuild kit from riff raff and getting machined (de lipped) pistons. Any help and advice is much appreciated. Thank you
ullyottj is offline
post #2 of 2 (permalink) Old 10-11-2019, 03:14 PM
Trust me, I got this...
Cummins Junkie's Avatar
Garage
Re: Tips on kinda building a obs 7.3 motor
Definitely replace the lifters with new motorcraft ones. You shouldn't need a girdle for your setup, but I suppose if you did get one it would only help.
Obviously make sure to get your heads and block pressure checked/magnafluxed, crank checked for out of round, etc as well.
Sent from my SM-J320V using Tapatalk
Shoulda bought a Cummins.
1997 F250 7.3L XLT, 4x4, 5spd, 315K, TS chip, BD Turbo-Thruster II, Donaldson 6637 filter, 4" straight piped dual exit SOLD
1995 F350 CCLB 6.0L WIP
Pain is inevitable. Suffering is optional.
Cummins Junkie is offline
