Hydraulic suspension for 4x4 1997 Ford F-250 7.3? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 09-21-2019, 05:00 PM Thread Starter
Hello psn, I’m looking for hydraulic suspension for my 97 Ford F-250. I have been looking for it, for this truck, and was wondering if there was hydraulic suspension for my truck? All I want to do is be able to change the ride height for my truck, with the press of a button, either on the dash or somewhere else that I could do it easily. Thank you
Rcemaxx is offline
post #2 of 6 (permalink) Old 09-21-2019, 05:15 PM
Bugman's Avatar
Re: Hydraulic suspension for 4x4 1997 Ford F-250 7.3?
Look at air bags.
I doubt that there is a hydraulic option out there for a F250
Bugman is offline
post #3 of 6 (permalink) Old 09-21-2019, 09:29 PM
Trust me, I got this...
Cummins Junkie's Avatar
Garage
Kelderman makes air suspension kits for all super duties, but that doesn't really help unless you axle swap, then maybe you could mod it to fit. Any Level Lift also makes just what you're looking for, but its for the 17+ super duties.
Shoulda bought a Cummins.
1997 F250 7.3L XLT, 4x4, 5spd, 315K, TS chip, BD Turbo-Thruster II, Donaldson 6637 filter, 4" straight piped dual exit SOLD
1995 F350 CCLB 6.0L WIP
Pain is inevitable. Suffering is optional.
Cummins Junkie is offline
post #4 of 6 (permalink) Old 09-22-2019, 01:18 AM
Project Shamu
Lt.Dan's Avatar
Any Level lift does exactly what you want, but like mentioned above, they only make it for newer vehicles, and modifying to fit would take ALOT of work
They use a little 12v electric hydraulic pump to drive a hydraulic ram, which pushes on a cantilever that actuates the height of a coilover. They also have a lot of special drag links and panhard bars to maintain correct steering and axle placement. Very expensive stuff
1996 Cali F350 CCFB, 7.3 PSD, 2wd SAS, w/ 378,000 miles.
New Motor at 352,000, DieselSite Legendary Trans at 356,000 and many more
Lt.Dan is offline
post #5 of 6 (permalink) Old 09-22-2019, 03:19 PM Thread Starter
Might just go with airbags then.... I’m also in the need of new suspension, and was wondering, what’s the best bang for your buck aftermarket suspension, and the best airbags that go with that suspension?
Rcemaxx is offline
post #6 of 6 (permalink) Old 09-22-2019, 05:32 PM
Garage
Sky's Offroad makes some killer shackle reversal kits for these trucks. That way you can lift it but not worsen the ride quality; you keep the factory springs. They even make a kit to convert to super duty springs as well. Not much experience with airbags, but you got Firestone and Air Lift that I know of.
