< 500 kms (300 miles) jectors in Block 5 yrs sitting. - PowerStrokeNation : Ford Powerstroke Diesel Forum
 4Likes
post #1 of 21 (permalink) Old 09-20-2019, 01:18 AM Thread Starter
Hey Guys,
Have some PIS injectors that have been in a block sitting for 4-5 years, ran for maybe 500 kms before truck was parked. Thinking about installing in current Tan/White truck along with aftermarket T500 pump that’s with the PIS 175/80s. Aside from new injector o ring kit anything to fret about?
Currently running supporting mods, e fuel, intake, exhaust ZF 5, no IC installed it’s on the shelf waiting.
Lastly, suggestions on tunes....
Thanx,
j
Tan white tan 97 ECLB, D60 PMF, RSK SD springs front, airs bags rear, 4:10, intake, FFD 205/30s, DP 4 exhaust DIY E-fuel, ZF-5 now
B&W turnover 5th wheel with Anderson hitch.
JCart is offline
post #2 of 21 (permalink) Old 09-20-2019, 03:17 AM
Project Shamu
Lt.Dan's Avatar
Re: < 500 kms (300 miles) jectors in Block 5 yrs sitting.
I think it'll be fine with new orings, if you're still worried, you can send the injectors out to get flow tested, or PIS would probably be happy to test them.
Tuning, I've heard Jelibuilt is a pretty darn good tuner, he'll be getting my money in the future, whenever im ready.
1996 Cali F350 CCFB, 7.3 PSD, 2wd SAS, w/ 380,000 miles.
New Motor at 352,000, DieselSite Legendary Trans at 356,000 and many more
Lt.Dan is offline
post #3 of 21 (permalink) Old 09-20-2019, 06:56 PM Thread Starter
Thanks Lt. Dan.
Ok so Ive had my tuner for some time and think the box got tossed. The Hydra Serial Number can be found where? Thinking Ill order tunes before I swap the jectors in this way in theory should be a seamless swap.
j
JCart is offline
post #4 of 21 (permalink) Old 09-20-2019, 07:05 PM Thread Starter
Originally Posted by JCart View Post
Thanks Lt. Dan.
j
Yeeesh....☺️😂🤣 got it sorted, imagine googled it.... phffff what I tell my kids all the time hahahaa.
Lt.Dan likes this.
JCart is offline
post #5 of 21 (permalink) Old 09-21-2019, 05:06 PM
Moderator
Sbluke55's Avatar
Haha. Just for everyone's info. You plug the chip into the computer. Open hydraflash and the s/n shows up in the bottom right.
JCart likes this.
01 f-250, Standard
Sbluke55 is offline
post #6 of 21 (permalink) Old 10-18-2019, 02:40 AM Thread Starter
Soooo update. Installed following Swamps online install directions. Oil In HPOP, e fuel shows 62psi, Optima yellow tops charged right up. AE initially said 2600 psi, 14-16% duty cycle. Nuthin no smoke out exhaust nuthin. DTC P1293 & P1294 open high side circuit right and left bank. Check harness visually, seems fine. Ran resistance ohms on all pins through VC to injector plugs 0.2 ohms. Ran ohms on injectors installed 2.9 ohms. Changed out IDM from 120v to a used 120 volt.... nuthin.
So my question is running A/E seems a little weird as it appears unstable, sometimes connects some times not. Not unhooked Hydra, yet as I thought Id ask first and second, should have Hydra on stock, meaning 00 setting yes?
Lastly A/E now says (if I try buzz test worked only once, heard all injectors too) undetermined fault. No other DTC #s.
Kinda bummin.... now I realize these have sat in a block for 4-5 years so very likely could be problems internally, externally when pulled they looked fine fuel and oil was present not dried or ####ty looking at all, O rings looked great, I did replace them with new prior to install.
Moving forward gonna send them out for testing and in the interim have ordered FFS 205/30% injectors.
JCart is offline
post #7 of 21 (permalink) Old 10-18-2019, 05:01 AM
Project Shamu
Lt.Dan's Avatar
If their is no smoke, its not meeting on of its 3 parameters. 100rpms, 10v battery, or 500psi ICP.
This is assuming you have fuel/air properly getting to the inj's as well. Which you said you have 62psi of fuel pressure and air is a given.
Can you check ICP another way? 2600psi is pretty high for just cranking.
The codes indicate like the injectors aren't making connection to the IDM. Could you pull the valve covers, disconnect the inj's and do a continuity test between the injector pigtail and the IDM pigtail? (Not at the 42 pin on the fender, but actually at the IDM)
Lt.Dan is offline
post #8 of 21 (permalink) Old 10-18-2019, 06:03 AM Thread Starter
Thanks for response Lt. Dan.
Engine ran fine prior to jector HPOP swap.
Starter driven rpms are quick enough to actually show oil pressure on dummy gauge in dash, rpm registers on dash so CPS is good, this is with extended crank of 40 seconds, so 2600 psi with a T500 pump may be good, 14-16% duty cycle seemed odd to me. I even cranked with ICP unhooked so PCM would revert to internal oil pressure tables. Nuthin.
As the A/E seems to be having a hard time “seeing” the PCM, I might 1) unhook the Hydra and try and 2) swap in a spare PCM. The other notion I had was to swap in a known working IPR from the HPOP I just replaced with the T500. This T500 sat with the 175/80 jectors too so IPR O rings might be pooched and/IPR sticking and/or armature is not making good contact.
In respect to engine harness continuity good suggestion, there is a process to check back through IDM, leaving Key On Engine Off and checking circuit to battery ground.. gotta read up on that a little more to get my head around it. Seems odd to me that both banks would fail with high side open circuit (I don’t understand this term either).
The common thread it appears, (at least to me) is, on both trucks they ran until jectors were swapped in. So I’m interested to see results of having them checked over and of course how new FFD 205/30% will do.
Guess I should also get going on IC install too geez and getting some gauges too.
j
JCart is offline
post #9 of 21 (permalink) Old 10-18-2019, 12:23 PM
Moderator
Sbluke55's Avatar
I would check your injector pulse rate while cranking. It's weird it wont start.
01 f-250, Standard
Sbluke55 is offline
post #10 of 21 (permalink) Old 10-18-2019, 12:27 PM
Moderator
Sbluke55's Avatar
A quick Google says bad idm. Do you have a spare?
01 f-250, Standard
Sbluke55 is offline
