ZF S5-47 in now upgrade rear DS? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 06-12-2019, 12:09 AM Thread Starter
Hey Guys,
Looking for input with questions.
Given I have to have a rear D shaft made up to accommodate ZF swap into Tan truck ECLB, with 3.5 RSK, blocks in rear to level. Im thinking of doing (1) single shaft, so need input from guys that have done this and (2) did you use the stock shaft ends or upgrade to SD flange on TCase rear out put and if so will one fit the BW 4407? And (3) Will rear yoke from SD fit the OBS 10.25 pinion?
Im thinking the SD style 1/2 cap on the rear yolk will be stronger then the OBS strap?
The OBS TCase output flange has a smaller dia ring on the flange then the SD flange so either change to SD flange (if it will fit a BW 4407). Or alternatively make a spacer to accommodate the OBS ring on stock flange and put the SD ring on the output side of the spacer to fit SD universal, hope that makes sense....
Lemme know what youve done. Slowly setting rig up to 450-500 RWHP range to be used as DD that tows if needed to 7-10k lbs.
Thanks Guys.
Tan white tan 97 ECLB, D60 RSK SD springs front, airs bags rear, E4OD 4:10, intake, DP 4 exhaust
Red 97 F250 CC 3:55, D60 Air Locker front, 175/80s, T500, TW files, Tymar, SD I/C, 6.0 fan, E-air, E-Fuel, RSK, SD springs front/rear, 145 litre rear tank (now ZF-5
JCart is offline
post #2 of 3 (permalink) Old 06-19-2019, 06:53 AM Thread Starter
Re: ZF S5-47 in now upgrade rear DS?
My DS shop Recommended I stay with a stock setup so thats what I did totally rebuilt, with spicers and new center bearing too.
JCart is offline
post #3 of 3 (permalink) Old Today, 03:06 PM
410customs's Avatar
good idea, cheaper and proven reliable setup
I am lucky the front and rear drivelines in my 97 were done just before I bought it
2001 Excursion 7.3, auto, 4x4, 3.73, collecting parts for suspension lift
2000 E350 7.3, auto 2wd, 3.73, toy hauler camper conversion...researching 4x conversion
21.9 liter family
410customs is offline
