97 OBS looking for Starter Swap info - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 04-15-2019, 08:37 PM Thread Starter
Hey everyone, I'm in the process of restoring my dads old truck and i'm in need of a new starter. I've read that the 01-03 SD starter is a better option due to the gear reduction. Is that still the best route to go?
I've also read about a DB electrical starter claiming it is superior.
If anyone can shoot me a little advice i'd appreciate it!
CamoX413 is offline
post #2 of 7 (permalink) Old 04-15-2019, 08:59 PM
College Student
Re: 97 OBS looking for Starter Swap info
I put a new OEM one from an 03 in a 95. Went in with out a problem.
95 Auto. 4.10 gears. SCLB. Stock besides Baby Swamps Injectors and TS-6 chip with swamps tunes. AFE MaxFlow. Glowshift trans, pyro, and boost. 6.0 IC KC TP38R. Converted EBPV to exhaust brake.
Cumminsdurastroke is offline
post #3 of 7 (permalink) Old 04-15-2019, 09:09 PM
alleged moderator
tjctransport's Avatar
my experience with the DB electric starter is they work great......until they don't and leave you stranded.
motorcraft starters or the one my friend builds for me last for a long long time and give you warning they are dying.
the two DB units i had worked, and then just stopped working. no warning at all.
tom
tjctransport is offline
post #4 of 7 (permalink) Old 04-15-2019, 11:01 PM Thread Starter
Okay so I'll probably stick with a SD starter then. Is it the starter with two bolt holes or am I looking for the one with 3?
CamoX413 is offline
post #5 of 7 (permalink) Old 04-15-2019, 11:12 PM
Bugman's Avatar
If you want one of the best starters out there get a Denso
https://www.nationsstarteralternator...28000-8420.htm
Just make sure that you don't get a Chinese knock off if your go to a different supplier
The Powermaster one from Summit Racing is also a good starter
https://www.summitracing.com/parts/pwm-9051
Or go to Rock Auto and get a Motorcraft one.
Bugman is offline
post #6 of 7 (permalink) Old 04-16-2019, 12:00 PM
Moderator
Sbluke55's Avatar
So what Iíve been looking out for is a 6.4 or 6.7 starter. You can swap the nose cone from a super duty starter onto them and have a kick butt starter with reliability. The kicker for the obs guys is finding two starter.
01 f-250, Standard
Sbluke55 is offline
post #7 of 7 (permalink) Old 04-22-2019, 01:45 PM Thread Starter
Thank you for all the great information guys. I went ahead and ordered the starter.
Also, I noticed that my dad had torn out the positive battery harness and the positive wire running to the starter because the factory harness was shot. I ordered a new harness as well. Do you all have a diagram where all the Positive wiring goes so that I can get it hooked back up?
CamoX413 is offline
Similar Threads
OBS starter swap to Super Duty type. Haztanker 1994-1997 Power Stroke Technical Info 11 01-13-2017 07:18 PM
2002 f250 starter burn out wire between solinoid and starter motor terryrolan New To The Nation 3 08-19-2015 02:58 AM
1994 F250 7.3L Replaced Starter (Starter Not Engaging) AirMech 1994-1997 Power Stroke Technical Info 0 08-05-2015 03:16 AM
need 6.4l starter install??---need help!! bad starter? jdreeves 6.4L Power Stroke - Technical Info 9 03-16-2015 12:56 PM
Starter locked up - fried wire from fender relay to starter solenoid TravisT 1994-1997 Power Stroke Technical Info 5 08-15-2012 03:48 AM
