Obs Sled puller build thread - Page 4 - PowerStrokeNation : Ford Powerstroke Diesel Forum
 10Likes
post #31 of 39 (permalink) Old 03-24-2019, 05:14 AM
no just hose even thought I planned new stainless line when I installed my 444fab kit . it says in the instructions on wiring it . Fixing to order another 444fab kit for another truck there nice kits .
78-79fordman is offline
post #32 of 39 (permalink) Old 03-24-2019, 12:44 PM
Native Texan
masakimm's Avatar
Garage
Re: Obs Sled puller build thread
I would run new lines the stock line are not big enough dor high Hp applications. And since u are building a sled puller I would think you are going to want some power. Mine is just a step above stock so I reused the factory lines for my kit I built.
Give it to Mikey. He won't eat it he hates everything. Hey Mikey!! He Likes It.
Upgrades:
masakimm is offline
post #33 of 39 (permalink) Old 03-25-2019, 02:48 AM Thread Starter
Makinnoyz1's Avatar
My instructions simply say "find a 12v+ ignition on wire to tap" but does not suggest a good place to do so
1996 f250- 238/100s, 67mm gtp38 1.0 a/r, adrenaline hpop, intercooled,e fuel, dan k tuning
l99 f350-160/30s, mb 17* hpop, dusty hosgate tuning
Makinnoyz1 is offline
post #34 of 39 (permalink) Old 03-25-2019, 10:21 AM
Native Texan
masakimm's Avatar
Garage
well u are removing the stock fuel bowl a good source would be the old feed for the fuel heater just trace the wire back to the drivers side and tap in there.
Upgrades:
masakimm is offline
post #35 of 39 (permalink) Old 03-26-2019, 01:41 AM
my instructions said the fuel bowl heater that's what I used is simple and easy location .
post #36 of 39 (permalink) Old 04-09-2019, 09:24 PM Thread Starter
Makinnoyz1's Avatar
Hey guys sorry for the long delay! but I got the injectors swapped in, the fuel system plumbed, and got the turbo mounted up. still need to mount the fuel pump under the truck, plumb it to the valley and wire it up. I ordered new intercooler piping and need to tackle that job. But everything has almost come together, very close to hearing this baby fire up! attached are some pics for your viewing pleasure!
post #37 of 39 (permalink) Old 04-18-2019, 11:42 PM Thread Starter
Makinnoyz1's Avatar
Has anyone here bought and installed the cheap bucket racing seats on ebay? are they even remotely comfortable? are they easy to make mounts for?
post #38 of 39 (permalink) Old 04-19-2019, 02:44 PM
Project Shamu
Lt.Dan's Avatar
I haven't, only used PRPs, Beards, Mastercrafts, and Sparcos. All very comfortable.
1996 Cali F350 CCFB, 7.3 PSD, 2wd SAS, w/ 372,000 miles.
New Motor at 352,000, DieselSite Legendary Trans at 356,000 and many more
1983 F150 SCSB Flareside, 302 w/ AOD Trans
2002 F450 SCFB, 7.3 PSD 2wd w/ 144,000 miles
SOLD
Lt.Dan is offline
post #39 of 39 (permalink) Old 05-09-2019, 11:19 PM Thread Starter
Makinnoyz1's Avatar
Ok folks I have an update! the truck is running! have a few bugs to work out. mainly the collector clamp is giving me some fits and I cant get a good seal, even with doing the clamp first then the pedestal. I ordered a new clamp hopefully that takes care of the issue. also need to get the tune sorted out. Then after all of that I need to start tracking down some boost leaks that I'm sure ill have. Hoping to make the first pull on the new setup memorial weekend if everything goes as planned.
HilhavenFarm likes this.
