Steel lines to the heads - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 04-15-2011, 05:00 AM Thread Starter
I aim to misbehave
chromehound's Avatar
I'm going to be replacing the bushing in my passenger side steel line that feeds the back of the head since it seems to be the source of most of my fuel leakage and was wondering if theres anything special I need to know.
chromehound is offline
post #2 of 5 (permalink) Old 04-15-2011, 05:14 AM
Patrick Feeley's Avatar
Re: Steel lines to the heads
Fuel Line Seals (seals lines at head inlet fittings)
(Ford) F4TZ-9C387-A (94-97)
Cheers!
Patrick Feeley is online now
post #3 of 5 (permalink) Old 04-15-2011, 05:50 AM Thread Starter
I aim to misbehave
^^^Already sittin on the seat waitin for good weather
post #4 of 5 (permalink) Old 04-15-2011, 01:19 PM
Moderator
PsRumors's Avatar
Then nope...nothing special. Simple R&R
'97 SCLB 4x4, 3.55, D60 w/ TrueTrac, 6637, Banks Techni-cooler, BTS Trans, Tru-Cool 4921 Trans Cooler, 1.0 exhaust housing, no ebv, 3" DP, Straight Exhaust, E-Fuel, TW tunes, International WP, 203*, Isspro Gauges
PsRumors is offline
post #5 of 5 (permalink) Old 04-15-2011, 01:49 PM
GoNavy!
DcMoore999's Avatar
Make sure you have a scribe because some times the old gets stuck in there pretty good.. Other than that, Nope.
2000 F-250, RCLB, Auto!!
DcMoore999 is offline
