Normal? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 04-15-2011, 04:57 AM Thread Starter
OBS Roller
Normal?
Is it normal when you turn the ignition switch to the run position (before starting) that you can hear something click like a circuit breaker almost. and the odometer goes blank for like 2 seconds and then comes back on?
97_f250_7.3L is offline
post #2 of 11 (permalink) Old 04-15-2011, 04:58 AM
INFAMOUS
LOSTCAUSEPOWERSTROKE's Avatar
Re: Normal?
Glow plug relay...
Camacho
99 F-350 Single cab LB 4x4 Just an old farm truck!
color="Red">BALLISTIC DIESEL PERFORMANCE
PROUD SUPPORTER OF THE RACE FOR THE WARRIORS!
LOSTCAUSEPOWERSTROKE is offline
post #3 of 11 (permalink) Old 04-15-2011, 04:59 AM
Running at last...
powerstroke cowboy's Avatar
Re: Normal?
Originally Posted by LOSTCAUSEPOWERSTROKE View Post
Glow plug relay...
97 CCLB 4x4 ZF6 [email protected]
powerstroke cowboy is offline
post #4 of 11 (permalink) Old 04-15-2011, 05:06 AM Thread Starter
OBS Roller
Re: Normal?
It is bad im guessing? I priced GP at ford the other day. They were 11.37 a piece.
post #5 of 11 (permalink) Old 04-15-2011, 05:19 AM
Running at last...
Re: Normal?
no the clicking sound is normal..
Too test if it is bad you need a voltage tester.. or two cold nights
post #6 of 11 (permalink) Old 04-15-2011, 02:00 PM
Re: Normal?
Odo behavior is normal too. If it clicks / blinks repeatedly, then worry.
madpogue is offline
post #7 of 11 (permalink) Old 04-15-2011, 02:40 PM
OBS Addict
7.3psd97444's Avatar
Re: Normal?
yeah and if its quiet enough you can hear the gp relay working. sort of a whine niose.
-Jordan-
97 SCLB 7.3 Handshaker
Valair Clutch, only the best.
TS 6 Position Tyrant Tuning
S&B, MBRP, Isspro, Mag-Hytec, 1.00 A/R Exhaust housing, HPX
Full sound system: Kicker-Kenwood
BILLET BADGES
Dick Cepek DC-2's/Duratracs
On-Board Air
Few cosmetics
PSA # 269
7.3psd97444 is offline
post #8 of 11 (permalink) Old 04-15-2011, 03:16 PM
Running at last...
Re: Normal?
Are pickup did that at one time and would not start.. So we cleaned the batterys and charged them and the problem was gone.. kind of funny
post #9 of 11 (permalink) Old 04-15-2011, 08:56 PM
Re: Normal?
Typical symptom of either a GP/GPR problem, weak batteries or, like your case, battery connection issue.
madpogue is offline
post #10 of 11 (permalink) Old 04-18-2011, 02:01 AM Thread Starter
OBS Roller
Re: Normal?
OK. I just wanted to be sure. It seems like i have an issue with starting. It will fire then die. Then fire then die. Then fire then almost die and then smooths out? Any ideas?
