Will being out of alignment cost 2 MPG? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 12 (permalink) Old 04-15-2011, 03:58 AM Thread Starter
Moderator
PsRumors's Avatar
Leading up to November I was consistently getting 17.5 MPG (hand calculated) and sometimes as much as 19.
In November I installed a D60 and BFG A/Ts (285s, same size as the previous set of tires). I had the truck aligned. Immediately I was in the 15 mpg range sometimes dipping into the 14s but never getting into the 16s.
I assumed the loss of fuel mileage was due to the raised front end with the F350 springs and the wide flat tread of the BFGs.
So yesterday I noticed some mild abnormal tire wear on the tires and took the truck to get aligned. There was a total of 2 degrees of total toe in as compared to the specs of nearly none.
So could this have caused my 2 MPG drop or maybe part of it?
'97 SCLB 4x4, 3.55, D60 w/ TrueTrac, 6637, Banks Techni-cooler, BTS Trans, Tru-Cool 4921 Trans Cooler, 1.0 exhaust housing, no ebv, 3" DP, Straight Exhaust, E-Fuel, TW tunes, International WP, 203*, Isspro Gauges
PsRumors is offline
post #2 of 12 (permalink) Old 04-15-2011, 03:59 AM
Haters Gonna Hate
Fordfreak4life's Avatar
Re: Will being out of alignment cost 2 MPG?
absolutely a possibility!
Fordfreak4life is offline
post #3 of 12 (permalink) Old 04-15-2011, 02:40 PM
OBS Addict
7.3psd97444's Avatar
-Jordan-
97 SCLB 7.3 Handshaker
Valair Clutch, only the best.
TS 6 Position Tyrant Tuning
S&B, MBRP, Isspro, Mag-Hytec, 1.00 A/R Exhaust housing, HPX
Full sound system: Kicker-Kenwood
BILLET BADGES
Dick Cepek DC-2's/Duratracs
On-Board Air
Few cosmetics
PSA # 269
7.3psd97444 is offline
post #4 of 12 (permalink) Old 04-15-2011, 07:22 PM
Built not Bought
1990 Scorpion's Avatar
It's a big possibility the truck being out of alignment would drag the tires more causing higher resistance.
1996 7.3L Powerstroke
T6 Chip with Tony Wildman Tunes
Autometer Cobalt Gauges
3 inch DP, 5 inch Straight Pipe
S&B Intake
Billet Torque Converter, Triple Kevlar Clutches, Transgo Shift Kit.
1990 Scorpion is offline
post #5 of 12 (permalink) Old 04-15-2011, 07:23 PM
PSN nerd
Yeah, my SD was doing the same thing tearing tires up got an alignment and picked 2 mpg back up. It always seems like when I would get new tires I would loose some mileage untill the tires wore in some.
97 F250SC 4X4 4 LINKED ON AIR <- FOR SALE!!!!!!
00 F350CC 4x4 I NEED A FLATBED FOR IT!!!!! LET ME KNOW IF YALL KNOW ANYBODY THAT HAS ONE
JAKE is offline
post #6 of 12 (permalink) Old 04-15-2011, 08:14 PM
STILL LEARNING
Bradbilt's Avatar
I say winter fuel
Bradbilt is offline
post #7 of 12 (permalink) Old 04-15-2011, 08:21 PM Thread Starter
Moderator
PsRumors's Avatar
Originally Posted by diesel_brad View Post
I say winter fuel
Has never had an impact before.
PsRumors is offline
post #8 of 12 (permalink) Old 04-15-2011, 08:40 PM
STILL LEARNING
Bradbilt's Avatar
Not quite sure if GA gets winter fuel, but up here it KILLS milage.
I guess you will have to drive it and tell us the results
Bradbilt is offline
post #9 of 12 (permalink) Old 04-15-2011, 08:42 PM
(520)465-7971
NotStock's Avatar
Definitely could but your definitely gonna see your tires getting eaten up if its that far out.
NotStock is offline
post #10 of 12 (permalink) Old 04-15-2011, 08:48 PM Thread Starter
Moderator
PsRumors's Avatar
Well, I have less than 1500 miles and probably less than 1000 miles on the new tires and the wear was not right. All the lugs still have the nipples but it could have gotten bad quick.
PsRumors is offline
