powerstroke dip stick tube - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 04-14-2011, 11:03 PM Thread Starter
pulled pass head off got it all back together dip stick will not go back in... from what i can see nothing got kinked but the stick stops 8-10 in down... how much of a pain is it to pull the tube
ben97 is offline
post #2 of 3 (permalink) Old 04-14-2011, 11:18 PM
Chillin's Avatar
Re: powerstroke dip stick tube
Have you ensured that you're not trying to make it bend against it's section? Like.... being that it's a strip of metal, you're not trying to shove it in so that it has to buckle thickways right? Make sure you rotate the dipstick and keep trying. A lot of times just flipping them completely over will make them happy.
Really sounds like it's stopping at the first downward bend.
Fwiw, you can pull the tube relatively easily, as it's just an o-ring seal to the pan nut and the nut on the front valvecover bolt that you already took off to pull the head. It just pulls right out once the nut is removed from the valvecover stud.
WHATEVER you do.... do NOT remove the large nut from the side of the oillpan. Don't even look at it.
I would do everything in my power to get that dipstick back in there without pulling the tube. That's a leak-prone area a lot of times.
Chillin is offline
post #3 of 3 (permalink) Old 04-14-2011, 11:24 PM Thread Starter
ya buddy of mine took that nut off when the belt broke the tube on his superduty curplunk fell the nut into the oil pan he paid a mechanic to get it out 1300 bucks later .... its gotta be stopping right behind the manifold but ive fought it for hours and even tried a dipstick out of a different truck... but anyway if the tube just pulls out of the pan then i guess thats what i'll do... thanks
ben97 is offline
