Creaking Noise Passenger Side Front Area - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 24 (permalink) Old 04-14-2011, 09:46 PM Thread Starter
Frenchb85's Avatar
Creaking noise passenger side front??
I have a creaking noise on the passenger side front, it doesnt make the noise when driving straight and on flat ground, sometimes when I turn ill hear it and always when im going over a bump such as a speed bump or uneven terrain. I replaced the upper and lower ball joints and both shocks on that side. the truck is lifted. Any ideas what this might be?
Frenchb85 is offline
post #2 of 24 (permalink) Old 04-14-2011, 10:23 PM
TBarrsTruck's Avatar
Re: Creaking Noise Passenger Side Front Area
Could be the leafspring eyelet bushings or cab mounts.
'97 4x4 ECLB: SD IC, TW 4 pos, afe, 3-4" w/areoturbine, 4 gauge, DIY stage 1s, GTP38R, cust E-fuel, E-brake, stage3 CM meth, 439hp still trying for 600. cust stereo, highamp alt, cust paint
'78 F-150 RCLB: 460 swap, 3" lift, 33's,Trussed 9" w/ chrome-moly shafts, cust stereo, locked front/rear. My first love! EFI & Turbo coming soon...
TBarrsTruck is offline
post #3 of 24 (permalink) Old 04-14-2011, 11:05 PM
Sodbuster Jr.'s Avatar
Sounds exactly like what my truck was doing, and it turned out to be the spring bushings. I would still check cab mounts to be on the safe side.
1996 F250HD 4x4, 270,000 miles, E4OD, 6637 Intake, Downpipe, 4in. MBRP w/muffler, 1705 Superchips, EBPV exhaust brake, CCV Mod, more to come...
1995 Dodge Ram 1500, 450,000 miles, Original engine (never been touched), Second transmission (Stage 2
), 6637 Intake, 4in. MBRP...after Flowmaster Series 40
Sodbuster Jr. is offline
post #4 of 24 (permalink) Old 04-15-2011, 12:15 AM Thread Starter
Frenchb85's Avatar
Thanks for the suggestions guys ill check those things out...TDeesTruck, are you still in the Corps? Im stationed at Pendleton...
post #5 of 24 (permalink) Old 04-15-2011, 12:33 AM
Built not Bought
1990 Scorpion's Avatar
My truck does the same thing let me know what you find out.
1996 7.3L Powerstroke
T6 Chip with Tony Wildman Tunes
Autometer Cobalt Gauges
3 inch DP, 5 inch Straight Pipe
S&B Intake
Billet Torque Converter, Triple Kevlar Clutches, Transgo Shift Kit.
1990 Scorpion is offline
post #6 of 24 (permalink) Old 04-15-2011, 02:50 AM
Offical Puddle Displacer
pstroke96's Avatar
Send a message via AIM to pstroke96
it could be any one of the bushings up front i would check them all. track bar, sway bar, springs, could be the u joint on the end of the axle maybe? also check the trans crossmember and skid plate bolts
Refugee
pstroke96 is offline
post #7 of 24 (permalink) Old 04-15-2011, 03:32 AM
Built not Bought
What's the best way to check if the bushings are bad?
S&B Intake
post #8 of 24 (permalink) Old 04-15-2011, 04:01 AM
Visually, they will be cracked and falling apart. No I've been out since June. Ohrah brother
post #9 of 24 (permalink) Old 04-15-2011, 04:03 AM
Nose picker
Check the bolts that hold the fender on.
02 F250 cc/sb 7.3 2wd 4R100
Denver is offline
post #10 of 24 (permalink) Old 04-15-2011, 04:33 AM
obs stroke addict
dego_red's Avatar
red
97 F-350 XLT CC/LB 7.3 auto 4x4 3:55's
95 F-250 Super cab LB 7.3 5 sp 4x4 4:10's FOR SALE SOLD
dego_red is offline
