95 F-Superduty , will not stop cranking after Engine swap - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 04-14-2011, 05:32 PM Thread Starter
97XLT7.3's Avatar
Ok , here is my problem , i just recently did an engine swap into our work truck , the truck is a 95 F-SuperDuty and the engine came out of a 96 E-350 Meatwagon. The swap went well but when i went to start it up it will not stop cranking until you disconnect the batteries. then when you try to reconnect them for the first 30 second after disconnection you get large arc as if there is a huge load on the cable. I have done the following things , Replace the Relay on the fender , new starter , checked all wiring , bench test the starter. With the starter out the system works perfect , and the starter bench tests fine , but with the system complete the problem returns , i have done everything i can think of and i am at a loss. So any help is greatly appreciated, Thank You in advance.
1997 F-350 XLT 7.3DIT ZFS-547 BW1356 Dana 60 Sterling 10.25 4.10's Utility Body, 235/85R15 Yokohama Geolander AT/S', Galaxy DX949 CB with Astatic Road Devil Mic and Dual 4' K40 Superflex Antenna.
Adding Soon : Lots of Apperance and Go Fast Goodies , Tune in for the Build Soon
97XLT7.3 is offline
post #2 of 9 (permalink) Old 04-14-2011, 09:31 PM
Re: 95 F-Superduty , will not stop cranking after Engine swap
That's weird, hoping I dont run into this problem when I go to fire up my truck.
02 f250
countryboyrob is offline
post #3 of 9 (permalink) Old 04-14-2011, 09:33 PM
Mpoage's Avatar
Could there maybe be something in the ingnition stuck? Im no expert by any means, just though I would throw it out there.
2007 Ford F-250 Lariat Outlaw 4X4
SCT X3 Tuned By Innovative Diesel
Straight Piped
Edge Insight
Mpoage is offline
post #4 of 9 (permalink) Old 04-14-2011, 09:34 PM
The Original
BigStroker's Avatar
What all did you swap from the van?
[CENTER]1994 F350 4x4 5spd, 1995 F250 4x4 5spd, 1996 F250 4x2 auto, 1997 F350 4x4 auto, 1997 F250 4x2 auto
#27
BigStroker is offline
post #5 of 9 (permalink) Old 04-15-2011, 12:37 AM Thread Starter
97XLT7.3's Avatar
The Engine. The Wiring Harness , Batt Cables , Starter , Oil Cooler DS Manifold , Valve Covers and all accesories are off the truck , so just the engine by itself is from the van
97XLT7.3 is offline
post #6 of 9 (permalink) Old 04-15-2011, 12:40 AM
Not Winning.
6.0 p-stroke's Avatar
It sounds like a solenoid is stuck or wired in wrong
Cooper
04 6.0 CCSB fx4
08 6.4 CCSB 4x4
Special thanks to:
Logan Schneider at CenTex Diesel Performance
830-885-6500
Originally Posted by Powerstroked162 View Post
Lets be honest here, how many times have you been on the receiving end of a "Cleveland Steamer"?
6.0 p-stroke is offline
post #7 of 9 (permalink) Old 04-15-2011, 12:42 AM Thread Starter
97XLT7.3's Avatar
wasnt sure of the wiring so i based it off of my 97 that i DD , i am thinking starter solenoid because if i disconnect the small wire from the fender relay that goes to the starter solenoid it still continues cranking
97XLT7.3 is offline
post #8 of 9 (permalink) Old 04-15-2011, 02:10 AM
===> Stuck or mis-wired solenoid. Maybe a piece of something conductive jammed between the solenoid wire and the big wire on the starter. This test ^^^^ rules out the fender relay.
madpogue is offline
post #9 of 9 (permalink) Old 04-15-2011, 03:52 PM Thread Starter
97XLT7.3's Avatar
thinking it is the solenoid as an issue , gonna just put a brandnew starter in and also run a ground wire from a starter bolt to the frame , just to make sure it has a good enough ground
97XLT7.3 is offline
